ST1100 - advice wanted
Alaska
91 ST1100
My primary use is my wife and I load up and travel on two week motorcycle rides, twice a year. We're pretty heavy with both panniers and the top box full of enough gear to go two weeks. The problem I've had with all my tires is premature wear on the sides of the tires. I think that this is because of the dual compound construction of sport touring tires combined with heavy loads.
I'd like to try a single compound tire. What do "cruiser" bikes use? I'd think that some of those giant beasts might use some pretty stout rubber. Any ideas on what is available?
Ron
Orlando
ST1100s
2432
Maybe up the pressure for a heavy load?
There is a stout Bridgestone tire made for a heavy BMW (maybe LT). It is the correct size for an 1100 rear. I think it has gone over 10K miles for a couple riders. It is a bias tire if that matters to you.
160/70 B17M/C79VTL5.004.00 - 5.00655
Some guys run a rear tire on the front for the extra miles.
Uncle Phil
4 ST1100(s)
002064
698
I have used this tire - a BT020 BIAS - for years on the rears of my ST1100s.
It is specced for the BMW K1200LT and handles fine.
I do run a BT radial on the front (whatever the 'radial of the day' is).
It is the only rear tire I can ride from Tennessee to Alaska and back - and yes I get close to 10,000 miles out of them.
Just beware that there is also a BT020 RADIAL for the rear.
Montreal
2009 ST1300A9
My Brother in-law had a K1200LT with the bias tires. He also had an ST1300 with Michelin PR4 tires, as did I. We were always surprised how much better tire longevity he got out of the tires on the BMW than either of us did on the ST1300 even though the LT is quite a bit heavier.
sirepair
Let's RIDE!
Chillicothe, Ohio
2003 ST1100P
7105
Let the stoning begin....
Darkside baby! But the change over on an ST1100 aint simple. You have to change to a GL1500 16" rear wheel, mod the brake caliper hanger and have different spacers made up for it to work. But I get 20K + miles on a GoodYear Assurance tire. Someone did find a CT that fit on the stock 1100 rear wheel, but it was a very low profile.
I too was going to suggest a car tire, but Pat beat me to it. When shopping for tires, pay attention to the load rating as well as the speed rating. Are you scrupulous in checking tire pressure? If you are loading the bike to capacity, this is very important. I destroyed a car tire by overloading it on a 1000 mile trip. The tire was done after 250 miles on a very hot day and probable under inflation.
I will add that if you are stressing the bike this way (long trips, loaded to capacity especially in hot weather*) preventative maintenance becomes that much more important.
*It is not likely that you are riding on your trips in the winter
kankakee
R1200rt
If your loaded up tire inflation cold should be at max pressure. I had a bridgestone h50 180/60 17 on the rear of my st. got 18k out of it. Load rate 75 (852 lbs) It's a bias belted tire for cruisers but bias tires are better for carrying heavy loads. The size is very close to the stock size. Had to deflate the tire to get it in but other than that it was a great tire. They do make the h50 in the ST size. . Paul from this site used Michelin Comander II (bias) and stated he would get 20k. out of them.
