Wow
I just wire em in and hope for the best....you two are getting too deep for me...
I'll be putting 2 Resistors there to cut the Voltage down as they will be on when lights are running as one in line only cuts the current down not the voltage..
Wow
I just wire em in and hope for the best....you two are getting too deep for me...![]()
about this again. Yes, if all the turn signal lights are switched to LED then an electronic flasher switch is needed. If I change only the front turn signals the flasher will probably just slow down. This upgrade has been done on an 1100 but I should imagine would be OK for the 1300.
Whilst touring Scotland last June Dave Whitley mentioned that when I was behind him he found it hard to tell if my indicators were on due to my under mirror spot lights washing them out. It's been playing on my mind and has been mentioned on here before. So today I decided to have a go at upgrading the front indicators.
I for once remembered to photograph the project, so here you go.
It's a simple upgrade using 6x 5mm bright white leds.
I took off the mirror pods and simply drilled three 5.5mm holes in the flat surface at the back of the indicator.
I soldered the leds in line with a suitable diode at the start of the feed.
Fitted them into the drilled holes with a smear of silicone around them.
Added (soldered) suitable lengths of wire and connected these to the indicator feed (green/yellow) and the corresponding earth (solid green).
And finally covered the whole mess with good old tank tape to keep everything in place.
OK it's not pretty but it is functional. I can't get the phone camera to get a decent pic of the indicators working. I can tell you that it was worth the effort though and for little outlay cost. I look forward to hearing what Dave thinks next time were winding our way through the Glens.
