I've stripped my oem shock down removing the spring, top adjuster and damping rod. I've made a drain point, drained the oil and flushed the shock out. My plan is to rebuild the shock with fresh oil and possibly a slightly heavier spring.
Can anyone tell me what the standard spring rating is? And what the standard oil weight is?
If i can find this out i can do an oil change every year as it's fairly simple to dismantle the shock.
regards,
Jim.
regards,
Jim.
