Have just been trying to remove the centre stand on my 2004 Pan (83K miles), as the foot lever arm extension has snapped off. Header pipes finally came off, but will not split at the balance pipe (seized solid), and I could only manage to remove one of the oxygen sensors (disconnected the left hand one at its electrical connector). However, there is enough access to get to the main-stand pivot pipe. Removed split pin and the right-hand securing bolt and tried to drive pivot pipe out - no chance, absolutely solid. The pivot pipe is mild steel and it sits in 2 large cast alloy lugs, which are extensions of the engine casing. It looks like the root problem is corrosion between the 2 metals. I have soaked the pivot joints with WD40, but to date, no joy. I'm loathe to use too much force in hammering the pivot pipe out, as I fear fracturing the alloy castings. Likewise, I'm nervous of using a blow lamp. Anyone have any ideas, or experience of this problem?
