ST1300 High speed buffeting/wobble: rear shock is the likely culprit
After chasing a front-end handling issue on my 2005 ST1300 for a while (91K), I want to share what I found in case it helps others dealing with the same frustration.
My bike had a persistent sensitivity to buffeting and instability above 100mph. Like many owners I suspected aerodynamics, tire pressure, or front-end geometry. I had done extensive front-end work , fork alignment, bearings, springs, without fully resolving it.
On the front end I replaced the OEM springs with Racetech units, which noticeably improved feedback and damping feel. I also removed an aftermarket fork stabilizer clamp that was introducing its own issues. Then I fitted Bridgestone T33. The T33's stiffer sidewall construction made an immediate and significant difference to stability and handling precision. The bike tracks naturally, holds its line with confidence, and the front end feedback is in a completely different league from the previous tires. If you haven't tried the T33 on the ST1300, do it.
But above 100mph the buffeting sensitivity remained, and with the front-end variables now largely eliminated, I could finally feel what was actually happening: the rear shock hitting its damping limit under high-speed inputs and rebounding faster than it should. That energy propagates forward through the frame and you feel it as a front-end response to a rear-originated event "like an echo". The front isn't causing the instability, it's answering it.
The OEM rear unit has no compression damping adjustment. At speed, under sustained buffeting loads, it simply runs out of authority. Preload and rebound alone can't solve it . The compromise between low-speed comfort and high-speed stability is a real ceiling with this shock.
Worth noting: a steering damper addresses the symptom at the front end but not the source at the rear, that may explain why results with dampers are so mixed.
For those who've been chasing this issue, I believe the ST1300 wobble is essentially a consequence of the limitation of the OEM shock.
My comment is just about the tyres. I have been riding the ST1300 since 2003 and fitted many different tyres over the years. When the Bridgestone T33 was released, I changed to them from the T32 which was being discontinued. The move to the T33 was quite noticeable and I rate them as the best tyre I've had on the ST1300.
I also agree that up to 100 mph the behavior is civil and requires all your attention over 100 mph and with an oversize trunk adds to the buffeting issue so if you plan on spending a lot of time over 100 mph loose the trunk as it really disrupts the airflow especially when running with the semi-trailers Just my 2 cents...
... and installing barn-door sized aftermarket screens... 🤔
Who's your beneficiary?
Good lord; I never even drive my Vette at sustained speeds like that!
I completely understand your concern. I dislike highways, but sometimes you can’t avoid them, especially on long interstate trips.
The reality is straightforward: remaining behind a large truck for extended periods is a poor risk-management strategy.
Many U.S. highways have speed limits of 75 mph, 80 mph, or even 85 mph, and trucks often cruise 10 mph above. This leaves you with two options.
The first is to stay behind at a safe distance to avoid buffeting, but then you risk another truck passing you and pulling in front of your bike. You’re also exposed to hazards like a trailer blowing a tire or an inattentive driver rear-ending you.
The second option is to stay ahead of trucks, which means passing them as quickly as possible, the slower you are, the riskier it gets.
The issue isn’t about choosing to ride at 100 mph; it’s about avoiding being trapped in a dangerous corridor.
You maybe know a better alternative, but I am afraid to say that’s just how it is.
I haven't ridden over 100mph since having a sportbike. But the east coast speeds are not as fast as in the west. My 2003 ST feels like it's going to disassemble at over 90mph (gps speed). Doesn't give a safe feeling.
