Re: ST1300-Saddlebag Power Without Disconnects
I installed 2 miniature relays into the system tonight to let the side led's act as additional turn signals. The Radio Shack part number is 275-0248 12v SPDT relay.
For anyone wanting to add this to a side light system, or any marker lights for that matter, so that they are synchronized with the turn signals, install as follows.
1) Cut the main power line to the side lights close to where you want to install the relay for that side. (Of course you can add more wire for a remote install.)Take the hot end of this wire and solder it to the common lead of the relay. Take the other end that goes to the side lights and solder it to the NC (normally closed) terminal of the relay.
2) You will need a jumper wire set for the turn signal pick up. A light weight speaker wire works perfect for this. Solder 1 end of each jumper wire to the coil terminals. These are isolated so it won't matter which becomes hot or ground. Now take the other ends of these jumper wires and connect 1 wire to ground and the other wire to the turn signal wire that corresponds with the side you are working on.
3) That's it, you're done. Test it. When the turn signal current is passed across the coil, the coil opens the normally closed circuit and turns the side lights off. When the turn signal current is lost, the coil loses power and the normally closes circuit closes and the side lights come back on. When the turn signals are off, your side lights stay on.
Total cost of this additional farkle: $4.69 x 2 = $9.38 + tax
