Article [13] ST1300 - Screen Mod
  • Thread starter Thread starter stuey
  • Start date Start date
OK, just made 5 sets and they are all spoken for. No more scrap lying around my shop, so no more will be made.
Sets for:
1) Zoran
2) George
3) Phillip
4) Greg
5) Indian Express (I need your name and shipping address, please email it to me. Your PM box is full)
Zoran, George and Phil's went out today. I need an address for Greg and Indian Express still!
Put mine on when Eric sent them a few weeks ago....finally got to ride it today.....first time in 3 months......38 degrees and windy.....went about 150 miles.....amazing difference.....the back pressure and helmet buffeting are all but eliminated.....helmet is much queter.........that air gap between the fairing nose and the windshield makes all the difference in the world.........thanks again Eric.....................................ff
Please post measurements or a pattern for the Screen mounting plates.
Inquiring minds want to know.
Thanks
If you read the first couple of pages of this thread there are pictures and dimensions..........the Eric ones I have are just a simple plate that extends the windshield out about an inch....no change in incline..........works wonderfully.............................ff
Hi.
I made the brackets today from organic glass as I found it easy to work on for the purpose to try the mod. I tried the offset by slightly more than 1 inch and also tried it at angle. Tested both variants on higher and lower screen setting. The best combination which worked for me was the upper screen setting and the bracket with perpendicular offssetting without any angle. Will test it couple weeks. The first impressions are the mod helps greatly to minimize the backpressure and also the noise.
Just want to say thanks to all the folks here who contributed to this thread. Great inspiration. Here is my attempt at making this mod. Like earlier prototypes it set the windscreen 1" forward and maintains the stock angle. When in the full up position it does position the windscreen slightly lower than stock due to the change in angle from fully down to fully up.Made from 1/8" x 1 1/2" steel bar stock. Just painted black. Next time I will learn to power coat. Initial ride of 40miles looks promising. Greatly reduced buffeting on my helmet and much less back pressure. I am only feeling a small amount of back pressure with the screen fully up. Here are my pics.
Has anyone ridden in a heavy rain after making this mod and if so how is that working out? Getting more water? No difference? ??
I have not ridden in the rain since. Prior to the mod rain would curl back around the wind screen. I can't imagine it would be worse. In any case I'm NEVER going back to stock. The reduction in turbulence alone is worth taking a chance on a little rain.
Another fabulous thread! Once again I am surprised to look down and see that I read 19 pages of posts. Many thanks to all those that contributed.
Beeker, thanks for pulling up an old thread, don't know if I would have read through it if you didn't.
When I get some time I will be giving this a shot.
Thanks to all who contributed.
Thanks for all the info, ideas and pics for mods here on the windscreen! :bow1:
I took a slightly different path and just modded the factory bracket itself, welding on these little wing lets that give me 3 position options at the bottom mount. The top mount stays the same. I'm using the middle position now and found things to be much smoother for both myself and passenger. The extra tab slips freely into the rubber slot w/o issue.
It also allows more none turbulent air to hit my body to help keep me cooler as the temps rise.
My next plan is to just cut it out so it's just a slot that allows me to set the bottom of the shield at any angle i wish.
BTW I have the only none electric windshield model out there, the 03 none abs. I also plan to try and source all the needed parts to go electric on the shield soon if it's not too costly.
Thanks again for the incite to these issues, I'm happier now.
Brilliant! That's pretty slick. Great idea! :)
