No I did not replace it.So you did not replace the bracket?
This tip is marvelous, I learned it from the neighbor who introduced me to bike restoration ages ago. Just a little caution. Select coins, dimes/pennies/nickels that are too large of diameter to fall inside whichever spring you are stretching.The pivot bolt gets worn and stretches, but so little that its hard to tell by looking at it.
While its never a bad thing to clean/paint/grease these points, a lot of folks think this is why the side stand stops "flipping" up by just touching it, when actually its the rubber sleeve that goes over the springs is what grabs and drags things. You'll find that spraying the inside of that, or applying some light grease, that your side stand will snap up really quick!
Another tip that may help, is taking a small screw driver and a handful of dimes, slip the dimes in between each coil, and this lengthens the spring and allows you to simply hang it in place.
Then all you have to do is take some needle nose pliers and pull the dimes back out, this saves you from scratching up all that nice paint you put on there.
A: Constantly amazed at how much more thorough the required inspections are over on that side of the pond. in my region all we usually get is lights, tires, and hornrolleyes
B: Also baffled by how many have said they have never touched their side stands. I have to lube mine a couple times a year or it won't retract. Yes it has a significant amount of wiggle and I try to be gentle with it.
A few points to consider. You have removed and replaced the springs at least once. Even though this is difficult, you managed it. The bolt is cheap and easy to replace, and after doing so, you can do a few tests to see if it has corrected the problem. Why spend $100 when $5 might be the solution - never mind the environmental considerations of throwing away a couple of steel parts that are perfectly good?Thanks for the tips- so are you saying probably just replace the pivot bolt then?
My wife said to replace the entire assembly and not mess around?
I got a picture of the pivot bolt, ( in post 11 first pic) it is unique in that it actually threads into the opposite side of the stand after you place the bracket between the stand... So I could not just put a bolt in that would test it because it would have to be the correct diameter and threaded on one end a different diameter. ( hope that makes since)(I don't remember if this is a shoulder bolt or standard metric item.)
Yes , A lot --with the bike fully loaded with camping gear-- I would stand on the peg and throw my leg between the camping gear and front seat.. ( gas stations, road side rests, restaurants, etc..).now I know obviously not a good idea.Do you mount/dismount with the bike on the stand?
Not a word of the side stand is even mentioned under any of the regular maintenance section of either the owners manual or service manual???if a rider neglects maintenance she/he will end up on the side of the road in one fashion or the other.
Over here free, unobstructed movement with instant, full retraction of the kickstand (once gently moved over the threshold) is subject of the annual MOT (mandatory safety inspection)...
Texas bike inspection requirements were last updated in the '60's. About all that's new is LED decorations...seems some people are distracted/frightened when they actually see a bike after dark.
Basic, so it's covered in the Common Service Manual...Not a word of the side stand is even mentioned under any of the regular maintenance section of either the owners manual or service manual???
No nothing is mentioned about the maintenance, or how,what to do, or even to do anything, only mentions the torque values of the side stand bolts.Basic, so it's covered in the Common Service Manual...
In all honesty -- do they really expect you to take half the bike apart to grease the center stand??? Remove plastic and headers- etc.. Not many people on here have done that I would suspect.. But again I'm not sure they expected people to own these bikes as long as we do.You do know that the service manual and the common service manual are two different books?
I agree 100% -- will do-- case closed..If you’ve been mounting her like a horse, you’ve probably bent the bracket, which is very common.
I think we are overworking this thread, but I'll add to the confusion.Yes , A lot --with the bike fully loaded with camping gear-- I would stand on the peg and throw my leg between the camping gear and front seat.. ( gas stations, road side rests, restaurants, etc..).now I know obviously not a good idea.![]()
Get the suspension sorted and you can take the spare side stand to a welder for lengthening.Okay everyone-- Took one for the team and ordered all new parts for the ST1300 side stand. Just under $100...
The verdict:
All new parts -- Bracket , pivot bolt, side stand, springs --- Drum role please-------
Made absolutely no difference at all-- The slop is by design-- Nothing is bent -- did not mount the bike in anyway to cause the side stand any harm.
So I have a complete spare assembly of the side stand that I don't need...but will keep just in case....
If you look at the video I posted earlier. New parts do the same thing..
Case closed again...![]()
