I started in re-building my (VERY simple) 1976 Yamaha XS650C air cooled vertical twin last summer. The engine was running OK but the front cam chain guide had disintegrated and needed to be changed. I didn’t do any bottom-end work at all - just the timing chain guide plus, because I was in there, valves and rings plus a bore, hone and two new pistons.
As I said, the XS650 is about as simple an engine as was ever put into a motorcycle, especially when compared with an ST:
- two cylinders (not four) in a single finned barrel rather than a large, expensive and heavy cast block;
- ONE intake and ONE exhaust valve per cylinder (4 total versus 16 for the ST);
- One cylinder head (not two);
- One camshaft versus four camshafts in the ST;
- Simple screw & locknut adjusters (NO buckets or shims);
- Four cute little cast aluminium valve tappet covers held on with nuts (no tricky seals or gaskets or stupid little “maintenance” covers to worry about);
- All timing marks clearly visible (you can touch them with your fingers - no flashlights, or even torches
required);
- NO balance shafts to synchronize;
- Air cooled (NO rad, NO thermostat, NO hoses, NO cooling passages anywhere);
- Two simple CV carbs which simply pop off the backside of the head (no EFI sensors / fuel pumps / HP fuel lines);
- Simple exhaust system - no electronics or O2 sensors - just a bunch of clamps, nuts and bolts;
- NO bodywork / plastic or other “ceremonial” parts at all;
Taking the XS650 engine out of the frame took 20 minutes (really) and then my buddy and I muscled it onto my workbench (it weighs 160 lb wet). Stripping it down to the bottom end with 8 studs sticking out of the lower engine case / transmission took another 30 minutes (head off, cylinder barrel off, camshaft out, wrist pins and pistons off the rods).
After the rebuild was done, it took maybe 45 minutes to re-install the engine from on-the-bench to started
and running. Now, I will grant that the XS650 makes about 50 HP (versus 125 for the ST) and the bike will
juuuusssttt break the ton (versus 240 km/hr / 140+ MPH for the big Honda) but the old Yamaha is an absolute blast to ride - and here’s the kicker about the rebuild job:
...as a result of a total failure of my bad knee and some factors at work, I ran out of time and had to farm the re-build out to a shop - and the bill was nearly $2000 CDN for labour and parts - and I supplied the gasket set which I had already bought.
If you started out to have an ST1300 engine rebuilt - I’d bet
my hat that the bill would hit $4-6K without any problem and a fair bit more if you had the shop do the R&R on the engine
and they did the job properly without damaging anything. My engine work was done by an excellent shop in London, Ontario called WolfeWorx and they did a superb job including vapour blasting the engine cases (that added maybe $250). Even if you did all the work yourself (except the machine shop stuff) I’ll bet it would still cost upwards of $2K in parts, depending on whether you needed new pistons etc. and it would be quite a task to NOT mess it up IMO. There are a zillion seals, gaskets, hoses, thingamajigs, doo-hickeys and watchamacallits that you will replace while you are in there - and they add up quickly.
When I priced having a Honda shop replace my clutch slave cylinder a couple of years ago, they wanted nearly $1800 for the job - most of which was labour to remove and reinstall the danged engine. The parts were quite a bit less than $100 (around $60-75 if I recall correctly). As we now know, the slave cylinder can fairly easily be replaced
WITHOUT removing the engine - so that would have been a goodly sum (around $15-1700)
wasted - to say nothing of the fact that getting the ST engine out and then back in without damaging anything would be...a challenge.
Anyhow - even if it ever became necessary, I sincerely doubt that there is any case in which rebuilding an ST1300 engine would ever make sense except as a very challenging and interestingly hobby project.
...just my $0.02 (which is around $14.37 CDN at the present rate of exchange).
Pete
