ST1300 turn signal bulbs
For anyone buying bulbs something to double check is the dimensions compared to a regular glass bulb. If they are too wide they won't fit in the lens opening and if too long they may not fit either.
Very timely thread, I was planning on a bulb changeout this winter and now I have all the info I need. Thanks all.
Greetings All, Related to LED bulbs:
On the 1300P there is a 3 pin flasher that is marked “led” and has wattage limits however, it does not work with LEDs, you get the hyper flash. On my 09 I used the resistors inside the mirror housing with clear lenses and switchbacks. On 2016 I would prefer not to cut into the harness. The 3 pin is not “standard” does anyone know where to acquire this type? I have searched multiple times on the web.
3CA605DC-322E-49B0-8709-5BE50B3059CA.jpegAnd this one
Try the search string 3-pin flasher for led lights
I tried it just now and got dozens of hits. Superbright LED was one of the top results on Duck, Duck Go. I don't know about other search engines like Google or Bing. The flashers I found had a different pin pattern than what your pix show. You may need to assemble some jumpers yo connect one to your harness.
Does anyone know if they make standard (non LED) 7443 front turn signal bulbs that are orange? I spent a little while searching online and this forum and wasn't able to find anything...
I'm working on a project bike that came with clear front turn signal lenses and for now I'd like to use a standard bulb (orange) in them.
