Hey
@LAron , I see the OEM socket with the wire and connectors is sold along with the amber turn signal lens from many sellers in the neighborhood of $90 USD.
Are you repairing something? If so what was damaged?
Because the socket with wires can be had for MUCH less via Amazon, ebay and others. A simple google seacrh revealed many new, compatible options. But only the OEM has the connecters to attach to the bike's wiring harness.
If you only need the socket, then your options are cheap as long as you can splice in the OEM connectors. If you need the connectors too, then your options are the OEM units - new or used - or you buy the proper connectors and attach them yourself. Be advised that the terminals (the metal part) in these connectors will require the proper tool to crimp them correctly. For me, buying the connectors and crimpers was an investment for further wiring projects. This may be too much if you don't need them for anything other than this one project.
You will need these connectors if those on the bike side of the wiring harness are intact and you don't want to replace them.
Does anyone have experience with removing these pins from the turn signal connector. I've tried a pin removing tool inserting from the front face but I cant get the electrical pins to release. I may have the wrong tool?
www.st-owners.com
Here's a source
https://www.cycleterminal.com/050-connectors.html
Partzilla has the socket, wires and connector separate from the lens, but not in the parts list for the ST1300.
The good news is that this socket is common across many Honda products, so you should be able to find those cheaper, compatible options if you look carefully.
