Adjustment of either end of the spring on the empty body will not "pre-compress"
What is called "preload"' adjustment.
You lost me there.
Preload adjustment is all about pre-compression.
That's the point I'm debating. What mechanism stops the bike from rising when you add preload?You lost me there.
That's the point I'm debating. .
Actually, "preload" controls ride height; damping controls bouncing.
As far as the preload making a difference to the ride, I suggest people try adjusting it and finding out for themselves. It makes a significant difference on mine.
Never left it. I still say that, as long as the suspension is not topped out, like when you're sitting on the bike, the length of the spring does not change length with preset adjustment.Intriguing. These are all questions you've asked before and all I can offer again is go back to jfheath's diagram, the one you posted yourself, where it is all very well illustrated.
Am I sensing that after all we discussed, the literature, the physics of the suspension dynamics, the facts, the evidence, you are now recoiling to your prior assertion?
I don't see how, unless the shock's damping varies through its range of motion.But don't miss the fact that under dynamic conditions, you know, like when the bike is in motion and bumping around, (that's where you might have to dive a bit into the actual physics of the mass-spring-damper suspension system to understand it) adjusting the spring preload alone will also affect rebound.
So after you change the preload to adjust your ride height, you will have also indirectly changed the rebound characteristics of the suspension, without having ever touched the rebound adjuster.
I ordered a Laminar Lip based on this review and several others on the Laminar site. I have yet to ride with it because it's 115 degrees here but am looking forward to reducing this buffeting behind semis as well. I thought maybe I was the only one, or perhaps something was wrong with my ST13.All good advice here, especially John Heath's (always) comprehensive post.
If you have the stock windshield, as I do, this is my advice based on 10+ years on my ST1300:
Buy and install the Laminar Lip:
I put this on my ST at the beginning and I wouldn't ride this bike without it.
The "lip" deflects the air up and over your head, and - most importantly - lets you ride with the windscreen nearly all the way down - at any sane speed.
You will be looking over, rather than through, the windshield. A world of difference.
With the lip, and the windshield down, the bike presents a much better aerodynamic profile to the oncoming air resulting in much less buffeting from trucks, and in all riding.
It's not totally eliminated, but is much less. You will also notice the bike feels, and handles, much better overall riding like this.
And looking OVER the windshield is much more pleasant then looking through it - and a dirty windshield really doesn't matter anymore
With the "lip", I ride with the windshield down always - and only raise it to clean, or in a heavy rain.
IMHO it's the only way to go....
I have had very good experiences with the Nivomat suspension from Wilbers. The suspension automatically adjusts to the load.
Function:
The patented Wilbers Nivomat system automatically ensures sufficient spring rate, damping and spring deflection without manual adjustments - completely independently via the hydropneumatic function and always ideal for the payload.
Look here:
Wilbers Suspension Manufaktur | Wilbers Nivomat | purchase online
Wilbers Nivomat - The "Wilbers Nivomat" shock absorber offers excellent comfort in all circumstances. It adapts to different loading situations without any effort on the riders part, automaticalle witwww.wilbers.de
Unless the shock is topping out, that's impossible. Plus, it won't be topped when you're sitting on it.You lost me there.
As far as the preload making a difference to the ride, I suggest people try adjusting it and finding out for themselves. It makes a significant difference on mine.....
....if I have full boxes and no pillion what would be the best setting from zero ( anticlockwise ) and what the little screw does on the right side of bike (when sitting on the bike ) through the hole in the right side footpeg hanger ??
Preload only adjusts the compressed ride height.
I raised the main stand and side stand by 15mm. Now the motorcycle is not too slanted and the rear wheel can be turned when the bike is on the main stand. See photos.
No. I use required steering effort to adjust rear suspension.@Larry Fine , wondering if you've done the suspension homework suggested by @ASPC?
I'm sure I would, but I would still revert to the setting that delivers best steering response.Set your rear shock(s) to Max preload and go ride a loop with plenty of varied bumps and holes. Do it several times at different speeds.
Then set it to min and ride the same loop again, several times and at different speeds.
Feel the difference?
I still don't see how, unless shocks have damping that changes as it travels through its stroke.Yes, statically, when sitting on the bike. But once you start riding, the preload setting affects damping.
I did watch some of it, but I didn't see how it applies to an ST1100 with OEM suspension.Did you spend a minute watching it?
No, I still don't get it. Does any of that video explain more than just watching him make adjustments?Could you clearly see how changing the preload setting (on the front in this example) affected the rebound?
I very much am. I'm trying to get it, but I didn't see an explanation as I skimmed through the video. I see the spring and the shock as two separate mechanisms that each do different things.Or just not really interested in understanding suspensions anymore?
To add, what I mean is I aim for the ride height that gives me the lightest, most neutral, responsive, and predictable steering. I ride 99% by counter-steering, and I look for the setting that requires equal effort to lean over and come back up again.No. I use required steering effort to adjust rear suspension.
