Yes I’m aware that the oem springs are progressive, but the only resource I can find is the spring rate is .61 kg/mm. Is that the initial value or the final value? Progressive suspension, the brand, lists their replacement for spring for the 1100 as being .63/.89 kg/mm initial/final.
I guess more to the point would be has anyone installing the Progressive springs found them stiffer or softer than the oem springs?
I am spring shopping, because I definitely need a slightly higher fork-spring rate than OEM to match my new heavy duty rear shock.
Mucho gracias.
Mucho gracias.
