I would be remiss if I didn't make this post. It touches on both recent threads I started - brake fluid change and fuel economy...
1. First, THANK YOU ALL!! For any of you who have followed my "journey" on brake fluid change, you'll be familiar with some of the psychological challenges I faced through this project. Your (collective) support has helped me get from zero to go, and helped me persevere through both my stupid brain-f@rt challenge of not removing the rear reservoir diaphragm (that had gotten sucked fully into the reservoir, and just looked like the reservoir lining to these eyes) and the psychology I became beset with due to my brain-f@rt with the rear diaphragm.
So, sincerely and emphatically, THANK YOU ALL!!
2. Confession #1...
Okay, so you were all correct... Changing the brake fluid is easy... (As long as you don't make a stupid mistake like I made.)
Apologies.
3. Fuel economy / Brake condition
So, these are linked (just like the braking system - linked brakes... Get it...?? I made a funny!)
It was Larry Igofar who last season suggested to me that there's a good chance my SMC isn't working well, and that's why the back rotor was getting hot and reducing my fuel economy.
Since changing the SMC and clearing/refilling the brake lines, AND doing a deep clean of the back brake, it took a few days for the back brakes to settle in... One of the earlier nights (first or second night) I took it for a test drive, it was still cold and foggy (7 degrees Celsius with a good ol' east coast fog), and that may or may not have had an effect on the brakes settling in.
Anyhow, after a few more test rides, I can tell quite clearly by viewing my fuel economy and just at stop signs, and backing down my driveway, that my bike rolls freely now! I won't say that I'm a brake expert, but I sure did a better job than the local "pro" shop that told me my brakes are fine and don't have any problems!!
I don't know (and likely never will) if it was the final rear brake piston cleaning or changing the SMC that cleared the problem, but it is nice to know I'm driving on a brand new SMC and that the back brake pistons are working well.
Again, I'm thankful to everyone for helping out and not cursing at me in the midst of my own personal psychological challenges, during which I KNOW I radiate darkness. Thank you for your patience and perseverance!
4. Confession number 2:
Regarding fuel consumption numbers, Sadelsor in the other thread on Fuel Consumption mentioned about doing manual fuel fill-up/usage versus distance driven calculations.
I did a correction for fuel consumption, but I only did a one-part correction. My odometer is 6% off (likely because my bike has a Speedo Healer installed, which likely corrects the Speedo but throws off the odometer the equivalent amount). At any rate, I was doing the correction for the odometer different (6%) but I did not add the FCD correction to this, which is an additional 5%.
So, even though based upon my former calculations last season (which I repeated several times to ensure and confirm consistency), this year I ONLY used my odometer 6% correction. So, with the total 11% correction, my bike seems to be getting a standard fuel economy. I need to remember, my bike has full wind deflectors (fairing + mirrors), and it has a Puig after market shield (which, while it is just as narrow side to side, it is SLIGHTLY taller and has some interesting bump-outs on the lower corners, which will add slightly to the wind resistance, ESPECIALLY when the screen is raised...).
So, after driving 90% or more highway miles, I got about 40 US mpg at 110-120kph. My temporary mpg is about 44mpg @ 110kph.
So, thanks Sadelsor for reminding me to do a manual calculation.
(It would be pretty nice if the FCD could be calibrated, eh...??)
5. I'm still making inquiries to see if I can find some people to regear the final drive. Just like my Shadow 750 that I first re-geared with a different sprocket, then re-geared with a custom (for my bike ONLY) gear ratio belt drive conversion kit, I hope to re-geared this bike with 12.5 to 15% ratio. You can all think I'm nuts... I really don't care!! But the proof will be in the pudding... I expect I'll improve fuel economy at high cruising speeds, and it's not just that... It's the busy-ness of shifting out of first and second in the city... A longer pull in first gear to get through turns without getting into high rpms would be really nice... That was a GREAT result of re-gearing my Shadow... Nice LONG pulls in each gear!! Much more fun to ride!
Okay, I think that's all my thoughts for today.
Again, thanks everyone for sticking with me, and sorry for my sometimes very dark psychology.
Rubber side down!!
2. Confession #1...
Apologies.
Rubber side down!!
