I looked through that list and eBay within 50 miles. In my budget there were few options at all, and all are way too big for the space I have available in my garage. There was a Rigid model that might have worked but it's bigger in every dimension and much heavier than the one I went for, plus it didn't have a hose or any fittings and I'd have to drive an hour each way to get it. I think the Campbell Hausfeld I went with will do the trick.Why new? Lotsa people buy these, then hardly use 'em
http://westernmass.craigslist.org/search/tls?query=compressor&catAbbreviation=tls&minAsk=min&maxAsk=max
Mr. Blrfl, sir, do you like this particular brand/model for some reason, or are you just saying an inline inflator gauge would be convenient?
Does this in-line gauge clamp onto the valve stem or is it like the service station model that only reads while you're pushing it on the valve stem?Yes on both counts. Mine's pretty accurate, has the perfect chuck for motorcycle wheels and should last a lifetime 'cause it's built like a tank.
--Mr. Blrfl Sir
Posted via Mobile Device
Yes, I typically let the air out of the compressor when I'm done with it and drain any fluid inside via the bottom drain.Joe,
OK, I'm a little confused. I kind of had it in mind that the 15gal Craftsman was something that you ran the compressor and it charged up the 15 gal tank and then you turned off the compressor and the tank would hold the pressure until it was drawn out.
. . . but, it sounds like you use the Craftsman to pressurize the separate air tank, then use that to fill tires when you don't want to run the pump.
Confused as usual on my learn'in curve,
Shuey
but . . . if I only get the compressor with it's integral tank, can I pressurize it, turn it off and use it like you do the separate air tank until it gets low on pressure?Yes, I typically let the air out of the compressor when I'm done with it and drain any fluid inside via the bottom drain.
I always air up the separate portable tank as it's just very convenient to walk it around and air up the bike or car tires quickly and it's always sitting there full of air.
Yes, it should be fine.but . . . if I only get the compressor with it's integral tank, can I pressurize it, turn it off and use it like you do the separate air tank until it gets low on pressure?
That's the crux of my confusion. Why two tanks?
Shuey
OK, thanks.Yes, it should be fine.
I was eating lunch.OK, thanks.
Shuey
PS: What took you so long! (rhetorical) Ha Ha
That could take all day!:eat2:I was eating lunch.
