At the last minute before tackling the wiring jumble I had to send for some proper wire strippers. Amazing how cheap they are . Adjustable for insulation thickness too . Like the man says "Made in China " .My plan is to disconnect the ABS fuse box and store that behind the seat. If I leave a few inches attached to the box it will be available if a later owner wants to resurrect the ABS system .That leaves enough room beside the battery for the normal fuses with a better fuse box (case ).I have a collection of "crimp and heat shrink "connectors to take away all the wire stretching and crushing . One other obstruction was a very large white plastic plug connector inside a soft plastic bonnet. That is not wired up to anything so I may cut that short too .The ABS has a huge built in collection of connectors sprouting out of the main loom . Most ABS plug ends are tied up in bundles behind the seat .
