It's where Honda wants you hang the little gremlin bell....
+1. Airplanes have this same tab so you know how high to fill. Actually, some have 2 (higher and lower) so you can still fill accurately if you dont want to completely filll the tanks. I fill to this line for consistency so I can track my mileage.Since it's lined up the the bottom of the fuel filler neck, I'm assuming it's an easier way to visually see the maximum level you can fill the upper tank to.
On side or center stand?+1. Airplanes have this same tab so you know how high to fill. Actually, some have 2 (higher and lower) so you can still fill accurately if you dont want to completely filll the tanks. I fill to this line for consistency so I can track my mileage.
I normally stay on the bike when filling. Unless I'm going straight home or otherwise parking soon, I will fill, wiggle, fill, wiggle, and fill to the top.I use to fiddle and put the bike up on the center stand to fill but found on longer trips, with it fully loaded, I was spending unnecessary energy for little to no benefit.
I always did that with all my other Hondas as they were cake to put on the center stand. Sometimes I put the ST on the center stand and sometimes I just straddle it up right when filling up though I may risk a fiery death. Just depends how I feel as I pull up to the pump.I use to fiddle and put the bike up on the center stand to fill...
Filling on the center stand allows one to put more fuel. One is likely to reach the bar quicker, while on the side stand. That is about all I can think.If filled on the stand does some gas then immediately go to the canister or someplace other to where the engine can eventually make use of it?
Uh yeah. That's the reason for putting on the center stand in the first place. But the original context was side stand vs center stand where the difference could be somewhat significant depending on projected/practical MPG. I'll rephrase I— was wondering if the fuel in the tank when fueled on the center stand would go somewhere it shouldn't once the bike was taken off the stand and returned to a perpendicular position with both wheels on the ground.Filling on the center stand allows one to put more fuel.
In my experience the difference is about half gallon.How much of a difference in fuel volume does it actually make between the two methods?
Enough to make the difference between making it to the gas station vs pushing it or using a gas can.How much of a difference in fuel volume does it actually make between the two methods?
Its probably the way your gas cap is situated on the Harley. On the ST 1300 it would spill out if I expected to put the same amount of gas as if on the center stand.My Harley surprised me when I filled the tank up while it was on the table lift, up to the full line, and I ran out of gas about 50 miles short of where I normally get.
On the side stand I get almost a gallon more in it.
That is more a function of planning versus the difference in fuel load between the two methods. Even with a 200 gallon tank a person would be in the same boat if they didn't fuel up until they were running on fumes.Enough to make the difference between making it to the gas station vs pushing it or using a gas can.
Now that surprises me. Even though I didn't think that it would be that much, I still wouldn't bother filling on the centre-stand unless I knew that I would be pushing my luck until the next available fuel, which doesn't happen often with an ST.In my experience the difference is about half gallon.
I only ever once filled up to the brim on the centre stand. Couldn't get the bike off the centre stand as there was a slight uphill incline on the forecourt. Very embarrasing!Now that surprises me. Even though I didn't think that it would be that much, I still wouldn't bother filling on the centre-stand unless I knew that I would be pushing my luck until the next available fuel, which doesn't happen often with an ST.
