Tiny Light above the Headlight
Sonny
Road Warrior
Sidney B.C Canada
2005 ST 1300A
8673
Does anybody know what type of light being used above the ST headlight
I want to replace it with LED and is it easy to removed?
Thanks
Sonny:bow1:
Kevin_56
Montfort, Wisconsin
20 R1250RT
6495
Yes and NO. If you can get your hands on the boot then you have half the battle won. I have replaced mine with LED's. I had my tupperware removed, so it was not too bad to put my hands on the boot. The boots are a press fit. You just have to wiggle them out. No twisting needed before removal. Just be careful that you do not dislodge the bulb while removing the boot with bulb.
When you remove the bulb, be careful not to drop it inside the reflector (there is a thread somewhere here where someone mentioned doing exactly that). Getting it out (if dropped) is difficult.
Avtrician
An LED light may not last long, others who have tried it have reported that the heat from the headlight destroys the LED..
Seattle area
2016 FJR1300ES
265
After trying several LED bulb types I have one which has been working for over a year and a half. These also worked for the same amount of time in my RX8 which was also cooking LED marker bulbs. I contacted superbrightleds.com and asked if they had any newer LEDs to try. They suggested the WLED-xHP5: 194 LED Bulb - 5 SMD LED Wide Angle Wedge Base WLED-WHP5: Cool White. These are the LEDs which appear to be working....
You can see what I've tried here:
http://koczarski.com/ST1300/LEDMarkers/Markers.htm
T_C
St. Louis, MO
2005 St1300
8568
I picked up a pair of Sylvania / Osram led's and so far they have survived a year and 3 months.
Not the cheapest alternative but they do last and draw considerably less power than the stock incandescent.
Throttlejockey
Padden is my hero
San Diego
06 ST1300
8080
Throttlejockey
Padden is my hero
San Diego
06 ST1300
8080
Hmm....I have HIDS. I wonder if they put off less heat than the OEM bulbs. I have had the WLED-6 bulbs for over 3 years.
FIreside Lakes WI
2007 ST1300
8355
