Having just watched a YT on the new style Givi, probably not an easy task to match to ignition key. The engraved key is using the middle of the blank, the standard uses the top and bottom. Matching either to themselves is pretty straight forward, mixing them, not so much. Pro Hack: if your key cut and wafer stack is close, you can always file it (tops of wafers protruding from cylinder when key inserted), just a little. You can rearrange them too, as you saw in the video.
Locks are just math, key cut, 0-9 matches wafer, 0-9. A zero cut will have a large center wafer section, a nine will have a short*. It gets complicated when you start trying to use keys not milled for the keyway, not impossible just harder, after all, they are called locksmiths. Best one I ever knew was a burnt out jeweler, he said it was so much easier and loved getting his hands dirty.
* Edit: I have this backwards, 9 is a deep cut, tall wafer...
