Hi All,
I was asked the questions below:
I was just looking at your hitch and I was hoping you might have time for a few questions?
Is it tubing / pipe or round solid stock? Thickness or Size?
Do you have any other pictures of the top of the rear verticals?
Do you know the approximate weight of the trailer empty / loaded?
Tongue weight?
Thank You very much!
Tinner aka Bob
Answered as follows:
The piping is aluminum tubing. Unfortunately I'm far from the bike right now so i cannot measure the O/D.
The top sides are lugs welded to the tops of the pipes that have holes through them. I have used threaded bar that goes through the plastic which is bolted (with double nuts each side) and is bent to go around the frame and has a plate that is
threaded through the threaded bar, goes under the frame and threaded again onto the threaded bar and locked int place with double nuts... Sounds confusing but isn't to difficult once you see. I will post pics etc when I get a chance. Unfortunately i had a very bad accident with the bike, so please be patient.
The weight of the trailer is also written on it so when I get back I will let you know...
The most important is the packed weight and the balance thereof!!!
The front hitch (on a bathroom scale) should weight about 5kgs only.
Balance is everything and also you cannot go crazy and speed with a load like this. Gotta get used to it!!!
I dont advocate towing unless you're an experienced rider! And then still be careful.
My last 2 lines was the reason I wanted to post this....
Thanks
