I have been researching trailer brakes for a camper trailer to be towed behind an ST1300. The trailer would be a Time Out Deluxe which weighs in at 385 pounds plus whatever cargo is added. Time Out sells a kit to convert this trailer to having brakes. It is pricey at $500.00 USD but the price is secondary to knowing whether it is safer with trailer brakes or without.
In researching this I have found everything from never pull a trailer without brakes behind a motorcycle because you will die all the way to never pull a trailer with brakes behind a motorcycle because you will die. Not very helpful. From what I can gather I believe that Time Out Trailers are equipped with Dexter Torflex light duty axles. I also believe that the brake conversion kit that Time Out sells is a Dexter trailer brake kit. The biggest dangers cited in both cases is the impact the trailer has on the motorcycle during hard stops. There is also a concern about the trailer brakes applying to aggressively (apparently it is difficult to control them properly to match motorcycle braking) and the trailer brakes applying either unexpectedly or much harder than expected.
In looking at the Dexter site I found that they do not recommend that brakes be used on trailers towed behind motorcycles.
From the Dexter website;
"BRAKES - Can brakes be used on trailers towed by motorcycles?
Dexter Axle does not recommend the use of brakes on small touring trailers designed to be pulled by motorcycles. Proper control of the brakes on these vehicles can be very difficult. Even the slightest imbalance of the trailer brakes might cause the rider to lose control. A secondary issue is the spontaneous and unexpected actuation of the brakes. This can occur when a Torflex axle is not fully loaded. Under this condition, the torsion arm is not rotated to its normal position, which puts the brake assembly out of level. If the axle is fitted with electric brakes, this non-level condition can result in unexpected brake actuation when the trailer encounters large bumps. This can occur because the magnet inside the brake has sufficient mass to move the actuating lever during extreme jounce situations. The farther the brake assembly is rotated out of level, the greater the chance that this spontaneous action can take place."
A lightweight trailer would not present an issue. I am wondering about a heavier trailer like the Time Out Deluxe. I know there a quite a few people on this forum who tow heavier trailers in the weight range of the Time Out Deluxe- 385 pounds empty. Some of you have trailers equipped with brakes and many more do not. For those of you who tow heavier trailers I would like your opinions about whether having trailer brakes is a good idea or a bad idea and why.
