The direction is correct. I made sure of that. I've just ordered new bearings and will check on proper tire shutting on rim, balance and since wheel will be down, the proper spacers alignment will be done.
I have the bearing & seal driver for the rear wheel. Front & rear if need pm me I'll send in the mail. Hold on to the swingarm tool & send all back at once?
Just replaced Tmoney rear bearing & seal past month.
Better yet Your only 80 miles away from Easton. bring tire/wheel/parts. We will fix/repair as needed. Have 2 types of wheel balance. plus weights.
Also Bob likely has better beverages...Bravo Bob!
Mark, I would suggest you take Bob up on this offer... it's always nice to get someone that knows STs to look at your bike. Some shops never see an ST and the experience is a definite plus.
Ok, sorry it took a day to respond. Busy yesterday.
Weekend is fine with me.
bob
Let's see. We'll get on it on Saturday with acedantinne. We'll keep you posted.
I really have to thank Bob and Tom for help. They were great!!! Bob was more concern about me driving home at night than me and that's always appreciated and he- they both have my respect. Thanks again guys.A quick follow up.
new swingarm installed, new rear wheel bearing & seals o-rings
alot of cleaning,mark & tom.
what was found= swingarm rotted=water ran into drive line. RUST everwhere. Not much left in the way of drive gear surfaces. This on the drive shaft it self.
Final drive wheel=Dampers & sleeves (alum.) egged shaped holder & screws gone no heads on the 5 screws.
drive hub that sets on wheel bearing worn beyond repair. the oring slot gone. spacer as thin as foil=replaced.
the tire= just over 1600 g of weight. removed. remounted tire. after cleaning wheel. balanced.
Thanks to Tom tmoney & Mark for all the help cleaning & keeping me on track. We ran out of daylight. So mark & Tom rode home at night.
The front end is very loose. As is u can move front forks back & forth.= That will be another day/weekend.
Mark stated the bike handle on way home about 50% better than ride here. We did not have X,or parts for front end work. Still need final drive parts to replace.
A word to all steel swingarm bike owners. check that rusted area. Could be water is getting into final drive?shaft area.
Honestly, I cannot even imagine what could have happened, and what would I do if we, and Many thanks to this site and people involved, didn't find out what's with the bike. I was under impression that PO was taking care of her- judged by how the engine runs and sounds.Wow!.............the more that was taken apart, the more neglect that was found. Glad you had the good help and looks like the bike is gonna be more importantly, safe to ride again.:yes:
