Hello all, I have been having trouble geting my Vista Cruise install to work correctly (I have the Yamaha version). I haven't been able to set it where when flipped on it will hold enough to keep the throttle locked and when disengaged still spring back. I think I finally figured out what's going on. My BMW grip is binding against the Vista Cruise housing - making it drag as the throttle tries to spring back when I disengage the VC. If I cut/trim some of the inside of my grip away, this will keep it from dragging - but if I do this, it will create a very narrow channel (maybe 1/16") between my grip and the Vista Cruise housing. Do you think water getting down to the throttle tube through this opening could cause me any problems?
Thanks, Brian
Thanks, Brian
