Caught leaking. I'm going to order parts tomorrow. Did anyone change the impeller shaft also?
Leaking water pump
Leaking water pump
After I had cleaned my cover up, I poured some oil in the clutch area of the cover and let them soak in there. just don't stack them up on top of each other, the oil needs to get into them all.Not bad 2 hours cleaning the surfaces. I measured my springs and some are at the min. length and the 1st clutch plate is near the min. I never done clutch replacement before... I ordered new clutches and springs. Can someone chime in on some hints on replacing the clutches. I know I have to soak them over night in new oil,,,, then.....
Here are links to two discussions that might be of interest to you:Can someone chime in on some hints on replacing the clutches.
Motion pro makes a brass putty knife type deal just for removing stuck on paper gaskets. This by far was the worst part of the whole job for me.the gasket looks stuck on.
Yes, It should be pressed in to the depth of the spec in the service manual.- Along with the new shaft bearing.Did anyone change the impeller shaft also?
