If one (and only one) air cut off valve membrane is wet from what appears to be fuel, what could be the problem? I have looked at the membrane, and it seems fine. I'll check it again with stronger light when I get access to it again though, just to be sure.
Tip for other newbies like me: when trying to remove the inner valves upper screws, spray them with carb cleaner first. I almost stripped both screws before doing this, and then they released very easily. And no, it was not one of the inner valves that where wet, it was carb number 4.
