What is it?
newington, ct
st1300
205
I admit it, I am a tool hog. If I see a hand tool I think I may need sometime in my life I will buy it.
So I was cleaning out my tool box the other day and came across this. I assume I bought it but for the life of me I don't know when or why. The only thing I know for sure is that it is for a bike, car or aircraft and not a boat.
So I'm calling on the group expertise to help me identify what it is and what it does.
It's a 10" long steel rod bent 90 degrees at the 4" mark with a 3/4" nut attached (braized?) on the end.
Veedersburg, IN
2004 ST1300
Looks like it would be for removing a nut or bolt from a hard to access location. Possibly a starter? As for which vehicle I haven't a clue but it would work on any of them.
It's got a threaded nut on the end. The long bar it's attached to would limit spinning it on a stud. But given enough room it could be used to rotate— something.
Maybe a handle for something? Run a bolt through a flange and screw it into that tool to carry something?
Running a bolt through a threaded nut into a threaded hole would be a very specific use case.
I can't imagine what that could be used for, but I'm sure it was a one-application specialty tool at the time you needed it. Since you can't remember what that one application was, its probably not something you're ever going to use again.
Dang....you beat me Mellow!
I only knew what it was because I have friends that work in a suspension specialty shop.
Good Job.
We should vote to make you Administrator of the Year :rofl1:
schlep1967
Bill
Harrisburg, PA
GL1800
7911
And I thought for sure it was Brooklyn Boy's first attempt at making his own highway pegs.
Joe takes the fun out of everything.
000540
And.........how long did you have to search for that?
I'd seen it before but just never alone like that... then it finally clicked where and it was a quick search... what took longer was for the search within my brain..
brooklyn boy
newington, ct
st1300
205
Mystery solved by Mellow, good job. It's the handle for a progressive shock compression tool. I had the handle in my everyday tool box and the rest in my tool chest. Shows how much I used it. I think I got it around 2005 when we were changing the springs on a 1998 VFR.
Thanks Mellow
that's odd, why wouldn't they just put a plain nut on it and have you use a regular wrench? Does that 90 degree bend in the handle make it easier to crank faster or something?
SupraSabre
Cedar City, Utah
12/04 ST 1300s
000420
5901
Maybe there's a matching ice cream maker that the handle doubles for!
kankakee
R1200rt
If you put a nut on it some one (me ) would run it down with an impact gun .:spank1:
But nothing is stopping you from doing that anyway (unless they used their own proprietary thread pitch that only their tool will fit)
