Yes, 2 slots in the WS cowl. That's one reason why I went with the BLM. I'll put the Buck on Sat. probably (with pix).Paul said:Don't you need to cut the dash for the Buck dash. I guess that would not be a big deal. I'd like to see one first.
crazykz said:For mounting lots of stuff.
Curt
Curt
It's a Ural!!rdfeatherstone said:I looked carefully and I can't tell what kind of MC is under all those gadgets
Ralph
Neil your right handlebar is almost completely naked. You're going to have to put something on that side to counterbalance the left.ccryder said:Here is my latest dash layout.
Neil S.
dond said:Paul I am in the process of changing over from a BLM to a Buck. The Buck faSTens to the WS runners and is more STable because of that. At leaST that's what I've been told. Jeff B has a Buck, perhaps he will input his experience.
The plaSTic mounted BLM is tolerable with an electronic compass and a Passport on it but I want more rigidity for future add ons, whatever they may be. I am sure that your firmer front suspension adds some bounce to the shelf?
I corrected myself Jeff...wjbertrand said:Don, I'm running a Ron Smith shelf, not the Buck. The RS shelf clears the full travel of the windscreen, at least when empty unlike the Buck. You are right though there is a brace installed under the dash cowl that stiffens the structure and a couple of the plastic push rivets are replaced with 6mm screws. Seems pretty sturdy and doesn't shake alarmingly at all. The way I have it configured, all of my farkles are also clearing the shield's full travel.
dond said:Yes, 2 slots in the WS cowl. That's one reason why I went with the BLM. I'll put the Buck on Sat. probably (with pix).
I juST checked the archives and Jeff has a RS shelf. How is that shelf working out Jeff? [end quote]
The Buck is advertised to allow full WS travel btw. We shall see eh?
Thanks for the input Jeff :
Check post #7 in this thread. I have the Ron Smith also. Or maybe you we're just joking but just in case...ccryder said:Curt:
Do you have a dash?
Sorry Don, I guess my reply came before your correction.dond said:I juST checked the archives and Jeff has a RS shelf. How is that shelf working out Jeff? [end quote]
