For a ST1300. What does the collective say on this size?
it all depends on what you expect. Lasts longer, yes, better cornering, debatable, pan weave possible and so on. Pros and cons.Why is the 205/50R17 better than the stock 170/60zr17?
I have run a few 180's. Have one on currently. No appreciable difference in tip in from the 170.So do the folks who fit a 180/55R17 motorcycle tire suffer the same “lean in” resistance over an OEM tire?
Anyone with actual experience with this setup care to chime in?
a car tire is fairly flat a m/c tire is rounded. There is going to be a big difference. Only minor differences' between different size m/c tires . see https://www.tacomaworld.com/tirecalcSo do the folks who fit a 180/55R17 motorcycle tire suffer the same “lean in” resistance over an OEM tire?
No resistance, you won't regret theSo do the folks who fit a 180/55R17 motorcycle tire suffer the same “lean in” resistance over an OEM tire?
MICHELIN® ROAD 6 GT 180/55ZR
It's a small world isn't it? Check for a PM from me.A couple years ago I bought a set of darkside tires and wheels from Jodog, and have run them for a while. I just decided to change back to my original wheels and tires, simply because I don't put a lot of miles on any more. It's an easy way to try out the darkside. I will most likely put them on the site for sale soon. I am in western Wisconsin, Eau Claire area. The rear is a Bridgestone drive guard and front is the Bridgestone rear mc tire that lots of people have run.
