Gus1300
I don't think you've destroyed your system; take a breath, step back and maybe start over from the beginning to ensure there's nothing you've missed in the process? Keep the faith...you can do this!
+1. I might be so bold as to add the “perfect” bike to ride Nova Scotia.@Igofar Nova Scotia is a great place to ride, and the 1300 is a great bike to do it on! I did multiple days there last Summer on mine.
My point is that it may not be the "perfect" bike for someone who knows nothing about working on motorcycles, who lives in a remote area, and me be better off with a smaller, simpler, bike to learn how to service and maintain stuff without all the stress and frustration etc.+1. I might be so bold as to add the “perfect” bike to ride Nova Scotia.
Thank you for your kindness and patience with this somewhat damaged human being that I am.I don’t think I’d call it stupid, because you’ve never done it before, and had no reference of what all the parts look like, or where they should be.
I’m guessing you have pressure on the rear pedal now?
Strap the front, and use your stick on the rear over night, and report back in the morning.
Glad your making progress.
The main highways are 110knp... I prefer to ride at 125kph. I did a road trip to Toronto last summer... About 3000km... One thing I wanted, and love, so much with the st13 is its wind and rain protection. It's basically cold here for 10 months of the year. Any other bike I'll freeze and get soaked. With my st13 i ride anywhere above 2 degrees Celsius, and I'm comfortable above 5 degrees Celsius. This is one reason the bike appeals to me. And I don't find it heavy at all (except if I accidentally park nose down on a slope). A smaller bike wouldn't satisfy me, and I'd still have to learn the maintenance since the local pros are mostly cr@p.Sitting here thinking about these past few days, and all the frustration and difficulties you’ve had trying to deal with this bike, started me thinking about not only your situation, but your location.
So I googled it.
Wow, Nova Scotia is beautiful!
Made me wonder why you would even want a big, heavy, complicated ST on those beautiful two lane roads and country side.
A smaller, simpler, bike like a Yamaha SR400, Royal Enfield Classic, Triumph T100, etc. would be so much more fun to ride over there!
Have you given any thought to downsizing to something smaller and simpler to work on?
Cheaper to run, cheaper to insure, easy to work on and repair?
My SR400 only has 2L of oil, the valve adjustments take 10 minutes with a 12mm wrench and a feeler gauge, tires and parts are nowhere near as expensive as your ST.
I’ve had a couple ST’s, and put 100k plus miles on them, but I have to be honest, I spend more time wrenching on them than my Harley’s or British or German bikes.
Just a thought.
I have not had so much fun since I downsized to this little 400 single, and have put 1000 miles on it in the past couple weeks.
Just something to consider.
You could probably easily turn your ST into a smaller street bike or dual sport like a KLR650, DR650, DRZ400, XT250, CRF250-300L etc.
I sure think you would have a lot more fun with something like that where you live.
Nothing wrong with liking what you like.
I could sure see myself exploring all those places on my CT125 loaded with fishing and camping gear.
You could always start wrenching on ST’s there since you probably now know more than all the local shops do.
So how did the brakes turn out when the dust settles?
Excellent observation DS. Flushing fresh DOT4 through the system will help keep the CSC from failing on you.Since I'm in the mood for flushing and refilling with DOT4, I should do my clutch since it is turning tea coloured
Thanks buddy. By no means am I a pro... The brake fluid is what it is... Igofar said soapy water neutralizes it, so any spills I've wiped and splashed with soapy water. There's no real way to totally prevent drips...Excellent observation DS. Flushing fresh DOT4 through the system will help keep the CSC from failing on you.
FYI, the bleed nipple which is located on the left side of the bike (as you are seated on it) just below the coolant bottle, will seem very tight compared to the brake bleed nipples. Leverage is your friend. Try extending whatever tool you are using to help you crack it open.
Use the search engine to read up on the technique to ensure the CSC gets a good bath.
DO NOT over torque the bleeder when you’re done.
You may notice the clutch fluid changing colour quickly (1k kms) after your service which means you will have to increase the service intervals until the CSC gets reasonably cleaned out. It’s a PITA to remove the Tupperware to access to bleeder but it’s still easier than having to swap out a CSC.
And remember to protect those surfaces during your service. Brake fluid is unforgiving.
Good luck although now that you are a pro, I doubt you’ll need it.
