Saint Joe
Had to come to a quick stop this am so used both brakes and now my front brake won't release! Any suggestions?? I'm using my blackberry so reading & typing sucks.
We pulled the bag off and didn't see or feel anything abnormal, so guessing it's something internal.Is rear brake caliper rotated forward and squeezing the rear hydraulic brake line? (If so, the rear caliper stopper bolt is missing)
Is the front SMC stuck 'forward', towards the front left fork tube?
Milo, so glad to hear you finally solve your brake problems! Good Job! I repaired two more Frozen rear brakes and SMC this weekend for other members. Same thing, Poor bleed on PCV and bone dry needle bearings in the left caliper pivot pin! I'm starting to believe that these dry needle bearings and galded bushing are most of the problems with the rear break dragging (as well as poor bleeding procedure).
I'm very proud of you! You never gave up....Only wish you lived on my side of the pond so we could ride together!
Igofar-Larry
It means the parts in the box are found on another fiche page which in the case of the lower pivot bearing is the fork page.Just looking into availability of parts, and according to one of the local Honda shops, it appears both the PISTON SET (45620-MCS-R01) and the more complete BRACKET SUB-ASSY. (06454-MCS-R01) will take about a month (4-5 wks) to get (none in Canada), and only slightly more $$ than listed on the fiche at ronayers.com so will likely just order locally (& support the local dealer).
What I would like to know is: What are the bold Letters & Numbers on the fiche?
e.g. the F-5 & F-5-1 and the F-10 (which I believe is the bushing with the needle bearings in it).
These items aren't listed below with the other part numbers. Are they found on some other web page?
http://www.ronayers.com/Fiche/TypeID/26/Type/LEFT_FRONT_BRAKE_CALIPER_('08)_/MakeID/1/Make/Honda/YearID/49/Year/2008/ModelID/8115/Model/ST1300/GroupID/386601/Group/LEFT_FRONT_BRAKE_CALIPER_('08)_
