Well after 101k with no problems I thought I had the dreaded leaking hose clamps. A few drops of coolant on the floor every morning. Pulled off the front cowl and right side plastic. No huge leak visible just damp running down the right side of the engine from the lower clamp area. Cleaned it up was able to tighten the clamp several turns. But now after looking at it again it appears the leak is coming from the bottom of the water pump. Running down the crease on the bottom of the water pump and the engine case. There is nothing coming from the leak hole.
Thoughts or a link to a related thread?
