engine running rough
Malton
st1100L st1100M
Hi There fellow st1100 fans well here we go again just got the bike out for a ride and it sounded ruff.
Looked at all the spark plugs ok changed them anyway
I have now found that if I take the left front ht lead off it runs the same when you go to connect it again it fires from about 1/2 inch off put it on and miss fires again.
Changed ht leads off my other st1100 and the same thing happens ANY IDEAS Please ?
Cheers Dave:confused:
This firing system fires two plugs at the same time, if that helps your thought processes.
?? Are you stating it will only run good without skip holding wire 1/2 inch away.
If that is happening then the plug is fouled.
also found this piece of hose any ideas where it go,s ??? its 2 inchlong ????SAM_0533.jpgSAM_0532.jpg
Thanks Guys do you think this could affect the running of the bike ?????
