I've had a strong gas smell (off my ST1100, not me ) for over a year now. I could never find the leak, only maybe a little evidence of wetness on the rear of the carbs, at least what I could see. So, I finally decided to to pull the carbs and get this solved. With many thanks to Adam Frymoyer and his excellent tutorial on ST100 carb removal, I pulled the carbs yesterday and found a puddle of gas on the mat underneath. Still a bit of a mystery though as I couldn't really find any solid evidence of the source. In any case, I've decided to send my carbs off to Billy Carr in Canton, TX to have them rebuilt. He seems to have quite a good rep for Honda V-4 carb work.
A few pics from the removal...
The 2nd pic shows the leaked fuel puddle on the mat.
While I'm in there, I plan to do the following...
[-]So, my first question is what is the p/n of the rubber mat? I've searched all the micro-fiches, with no luck.[/-]
Found it... Honda p/n 19050-MT3-000. It's not cheap... $60-$80! I guess I don't have much choice, my old one came out in pieces.
Comments and suggestions are welcome and thanks in advance for your help.
-Paul
- Rebuild the carbs, as discussed above
- Replace the rubber boots/insulators (16211-MT3-000)
- Replace the float bowl drain hoses (16196-MT3-610, 16197-MT3-610)
- Replace the two coolant hoses (19504-MT3-000, 19506-MT3-000)
- Remove the PAIR system (maybe)
- Replace the rubber mat below the carbs (19050-MT3-000)
-Paul
