I recently "upgraded" from a Zumo 550 to a Zumo 396. Trying to navigate a route I created on Basecamp has opened up a can of worms. Has anyone here mastered this beast? I'm guessing I need to do things differently in Basecamp to make it all work.
The problem might be caused by having a different version of the map on your computer than what is on your 396. Garmin releases map updates for the 550 & 396 twice a year (updates are released 4 times a year for newer models). Check the version of the North America map that is on your computer against the version on your two GPS devices, and make sure you have the same map version on all three devices - for example, "Garmin City Navigator North America 2021_20". If you need to update the map on any of the devices, you can accomplish that using Garmin Express. If the map on your computer needs to be updated, you will need to press "Map Details" and then "Map Options" on Garmin Express, then choose "Install to Computer" from the drop-down menu.I recently "upgraded" from a Zumo 550 to a Zumo 396. Trying to navigate a route I created on Basecamp has opened up a can of worms.
This document is going to be incredibly helpful. Thank you very much for the link and the tips. Now I have to digest it all. I have made many of the mistakes that you describe in your scenarios, and I think as a result, your explanations of what happens and why are all starting to make sense to me. Thanks for taking the time to put this all together.The Trip Planner App on the later Zumos is a different beast from the 550. The routing points behave differently and confusingly, terms that you may have used for the 550 now seem to have a different meaning.
For example, a Waypoint is NOT a point in a route. It is a point that is created and saved so that it can be used in a route at some point in the future - perhaps immediately, perhaps next week or next year.
A route consists of a combination of Via Points and Shaping Points. These do the same thing, but behave slightly differently when navigating. Typically i will use maybe 5 Via Points in a route which coincide approximately with stopping places. Start, finish, morning, lunch and afternoon breaks. I use a load of shaping points in between to pin the route onto particular roads.
If you use. Waypoints in a route, they then become either a Via Point or a Shaping Point. by default they are added to a route as Via Points, but It is up to you to choose - The Zumo will announce as you approach and arrive at Via Points, but the satnav insists that you visit them. Shaping points are a little more forgiving.
But Via Points are regarded by the Zumo as key points or destinations, so it will display the Via Points when starting a route, and you can display information about Via Points at the side of the screen eg ETA, distance, how long before arriving at a Via etc.
One advantage of using predefined Waypoints in your route is that the name is transferred to the Zumo from Basecamp. For points created in any other way, the Zumo tends to ignore the name allocated by Basecamp.
Knowing how these behave is key to plotting a route in Basecamp.
I tore my hair out with this when I switched from having used a 550 and 660. But eventually worked out how to get the best from it.
It is all documented in the document in the link below. It has lots of illustrations, examples, explanations and suggestions as to my preferred methid of planning a route. It is probably much more than you will ever want to know, but if you are planning long trips, the Zumo is quite capable of taking you on a completely different route if you don't know at least some of this stuff.
It is written specifically for the 590 and the 595 when used with Basecamp. Much of the first three sections will apply to the 396 as well. Never having had my hands on a 396, You will have to check one or two things out, but from discussions with others it seems to be similar, perhaps tending more towards the 595.
But first, get the maps on Basecamp and the Zumo to be exactly the same versions. And dint update the map in your Zumo without updating the map on your computer at the same time.
If using an old route, make sure it is recalculated for the new map before transferring it to the Zumo.
The pdf is attached to post #1. For your use only. Please observe the copyright notice.
Article - Zumo 590 & 595 Trip Planner & Basecamp - What Goes Wrong and Why | Articles
A detailed analysis of how the later Zumos (with the Trip Planner App) work together. This is the result of many hours of working out how my Zumo 590 and 595 behave with routes created in Basecamp and results in some recommendations for trouble free route planning. The on-line Issuu version...www.st-owners.com
Hope this helps.
I have made many of the mistakes that you describe in your scenarios.
