HP4M - will it cause a problem?
Norwell, MA
2004 ST1300
6095
I’m loathe to start another oil thread, but my question os very specific.
Honda dealer was out of HP4S and I picked up 4 quarts of HP4M, confusing t with the regular semi-synthetic.
the “M” is for Moly and I read it could cause clutch slippage and that the oil is intended for high rpm, high heat, sever use, the opposite of my ST1300
Should I
a. return it Monday
b. Mix it with some non moly oil I have
c. Just use it.
Montreal
2009 ST1300A9
Honda has an asterisk next to the HP4M oil that states;
They also state the below;
The negative part about moly is that it can build up on clutch plates and accelerate clutch slipping on a clutch that is already starting to wear. It takes several thousand kilometers for the moly to accumulate enough to cause this slippage.
a. return it Monday
Is it really that difficult to make a decision? Its your bike, your oil, your time. What are the advantages to keeping the stuff for use? What are the disadvantages? What is the probability of it causing a problem? Do you live 400 miles from your dealer, i.e. is returning it an onerous task?
I'll answer a question with a question. With all the approved oils out there, why would you even contemplate using an unapproved one?
illinois
2000 ST1100
I'd of bought the regular GN4 Honda oil if it were me and called it a day:)
010688
Return it on Monday.
It was developed for Honda dirt bikes that have a separate transmission from the engine sump. It is not recommended to be used in a Honda motorcycle with a transmission that is all-of-a-piece and shares a common lubrication oil. It will ruin the clutch in your bike.
STeveMcD
Norwell, MA
2004 ST1300
6095
Wow
Montreal
2009 ST1300A9
Just for the fun of it, since this is an oil thread, I thought that I would throw in what Honda lists for viscosity ratings based on the year of the motorcycle. This is what Dave (@dduelin) has been writing for quite a while, that Honda changed their recommended oil viscosity from 10W40 to 10W30 in 2007.
STeveMcD
Norwell, MA
2004 ST1300
6095
I found the no moly in the service manual. Yesterday I was running from by son’s house where we had to disassemble his gazebo ahead of the storm, to his fiancee’s shower in RI, to the dealer, to my nephew’s birthday party. I was on the ST and it was hot.
I rushed the oil purchase and when I realized the “M” might be a problem, I asked here.
I left it alone and picked up Mobil 10-40 synthetic motorcycle Oil at the local O’Reilly’s.
The filter put up a helluva fight because last time I flowed the manual and torque it to 20 ft/lb, which seemed more than normal.
Eventually I got frustrated, my son and I tipped her over on the passenger side, I drilled a hole in the cap wrench and then into the filter and sunk a serious self tapping bolt in. It still took a mighty tug on the wrench and I could see the cap wrench trying to slip but the bolt stopped that nnonsense.
The final drive oil was its normal 1 minute job, thankfully.
All good now.
010688
I find this stuff has approval.
The owners manual has three requirements. API service classification, JASO service classification, viscosity. This oil only meets two.
Your 2005 owners manual probably has a page similar to this from the 2003-2006 St1300 Service Manual:
rogo
Duluth GA
'05 ST1300
000474
My coldest ride this year was 25 degrees. Thanks.
Interesting that you thought we would know more than Honda's manual. It's been said by a number of guys in many posts in those links I sent in the last thread called "Oil" that most guys here echo what @dduelin said in post 14 above "Go by the Manual". Or, my phrasing, when all else fails, read the instructions.
Isn’t it ironic that oil threads cause more friction?
Can't put out a fire with gasoline, evidently cannot solve friction problems with more oil. (Ya know, for a while years ago, the hot set up was to add a few ounces of a molly additive to the oil in the final drive. Maybe that would reduce friction here too? :biggrin:
