I have found that adding Red Oak sawdust created by an 80 tooth blade at oil changes, makes the gearbox so much smoother. It also ensures that the filter bypass valve will operate as it should.
Is it really that difficult to make a decision? Its your bike, your oil, your time. What are the advantages to keeping the stuff for use? What are the disadvantages? What is the probability of it causing a problem? Do you live 400 miles from your dealer, i.e. is returning it an onerous task?
I'll answer a question with a question. With all the approved oils out there, why would you even contemplate using an unapproved one?
While I didn’t have the manual with me when I bought the oil, and hadn’t pulled it out of the garage when I started the thread, I apologize for troubling you.Interesting that you thought we would know more than Honda's manual. It's been said by a number of guys in many posts in those links I sent in the last thread called "Oil" that most guys here echo what @dduelin said in post 14 above "Go by the Manual". Or, my phrasing, when all else fails, read the instructions.
I alway's tighten any oil filter car or motorcycle by hand. Been doing it now for some 50 years...so far so good.I found the no moly in the service manual. Yesterday I was running from by son’s house where we had to disassemble his gazebo ahead of the storm, to his fiancee’s shower in RI, to the dealer, to my nephew’s birthday party. I was on the ST and it was hot.
I rushed the oil purchase and when I realized the “M” might be a problem, I asked here.
I left it alone and picked up Mobil 10-40 synthetic motorcycle Oil at the local O’Reilly’s.
The filter put up a helluva fight because last time I flowed the manual and torque it to 20 ft/lb, which seemed more than normal.
Eventually I got frustrated, my son and I tipped her over on the passenger side, I drilled a hole in the cap wrench and then into the filter and sunk a serious self tapping bolt in. It still took a mighty tug on the wrench and I could see the cap wrench trying to slip but the bolt stopped that nnonsense.
The final drive oil was its normal 1 minute job, thankfully.
All good now.
Just a point of reference for those who might be interested to know.I find this stuff has approval.
You may want to enlarge that picture shown and read the label again. I see JASO MA and more on that bottle.Just a point of reference for those who might be interested to know.
There is currently (as of August 01, 2021) no Shell Rotella engine oil that has JASO MA certification. The Rotella oil container pictured above does not list or claim a JASO MA certification.
The only Shell oils that currently have JASO MA certification are the Shell Advance Ultra 4T line.
Don’t drag me into this post, I’m on vacation and have been surfing all day.While I didn’t have the manual with me when I bought the oil, and hadn’t pulled it out of the garage when I started the thread, I apologize for troubling you.
I don’t think the manual says anything about Rotella, or dark side, or a million things Igofar has learned, and I thought it might be reasonable that some folks here had used it and would let me know their experience.
Again, I”ll make sure I always have plenty of time and have done all my research, with appropriate citations, before troubling you again.
p.s. Everyone does dumb stuff and asks dumb questions, not everyone needs to reply like a dick
Yes you do, but you do not see it written anywhere on that label that it is JASO MA certified, because it is not, which is what I wrote.You may want to enlarge that picture shown and read the label again. I see JASO MA and more on that bottle.
Or maybe to many Piña Colada??You are correct….too much sun and surf today.
Next time this happens, if you over tighten it, just drive a screwdriver through both sides and twist it off. Easy, peasy.The filter put up a helluva fight
Easy, peasy, and MESSY.Next time this happens, if you over tighten it, just drive a screwdriver through both sides and twist it off. Easy, peasy.
STeveMcD, at the risk of being stoned to death by Igofar for oil filter heresy, here's my method for sticky filters.I drilled a hole in the cap wrench and then into the filter and sunk a serious self tapping bolt in.
I should have stated this stuff has my approval. I often enjoy the oil threads. It was the Yuenglings that actually gets me to reply to one.Just a point of reference for those who might be interested to know.
Larry, I hope you are enjoying your vacation. You should stay there an extra week or two, you've earned it.You may want to enlarge that picture shown and read the label again. I see JASO MA and more on that bottle.
Maybe not enough....Or maybe to many Piña Colada??
Always? That’s a stretch.Don’t drag me into this post, I’m on vacation and have been surfing all day.
Besides, I didn’t foolishly torque my oil filter to 20 foot pounds just because of a miss print in the manual.
And why do you always end your posts calling somebody a dick?
