yep, Barkeeper's FriendClick link for procedure.
Bar Keepers Friend.
This is not recommended.Use Bar Keepers Friend, make a paste in a small bowel,
Neither is ‘wife right off’.This is not recommended.
Nice @Willsmotorcycle !
So the Barkeepers Friend to use is the powder version? Does the liquid in a plastic bottle perform the same?
My mufflers are in dire need of the same TLC
Do you recommend rubber gloves?Polishing them takes way too long.
Use Bar Keepers Friend, make a paste in a small bowl, wet the mufflers, and apply the paste, then let it sit for just a couple minutes.
The chemical is what does the cleaning, not the rubbing, or polishing.
They will look like chrome when finished.
Best results use a soft cotton diaper or cloth.
Do NOT use any scotchbright or steel wool, no matter how soft you think it is, as it will scratch and show swirl marks.
For anything burnt on your pipes, use Easy Off oven cleaner (carefully) and it will wipe right off.
Yes, I did the other side with the squeeze bottle, but did not want to confuse the issue. Worked the same, little longer soak time.Nice @Willsmotorcycle !
If you leave them on the muffler to long they will melt.Do you recommend rubber gloves?
Everybody's a comodianIf you leave them on the muffler to long they will melt.
