Cleaning mufflers
Polishing them takes way too long.
Use Bar Keepers Friend, make a paste in a small bowl, wet the mufflers, and apply the paste, then let it sit for just a couple minutes.
The chemical is what does the cleaning, not the rubbing, or polishing.
They will look like chrome when finished.
Best results use a soft cotton diaper or cloth.
Do NOT use any scotchbright or steel wool, no matter how soft you think it is, as it will scratch and show swirl marks.
For anything burnt on your pipes, use Easy Off oven cleaner (carefully) and it will wipe right off.
STRider
Oregon
2012 ST1300A
50
Nice @Willsmotorcycle !
So the Barkeepers Friend to use is the powder version? Does the liquid in a plastic bottle perform the same?
My mufflers are in dire need of the same TLC
RichKat
Rhome Texas
2011 ST_1300 PA
9102
Do you recommend rubber gloves?
Willsmotorcycle
Ride more...
Makefield Highlands PA
2016 ST1300P
002771
Yes, I did the other side with the squeeze bottle, but did not want to confuse the issue. Worked the same, little longer soak time.
W0QNX
Blacksheep Tribal Member
Pensacola, FL. USA
06/ST1300 19/R1250RT
007437
Y’all keep on polishing all you want. The best thing is “the works” toilet bowl cleaner. Don’t doubt until you try it. It will even clean the elbow joint area with a small amount of polishing action.
rjs987
Robert
West Des Moines, IA
2022 Kymco AK 550
001059
8058
Anyone here tried plain old household aluminum foil crumpled a little and dipped in water and just rubbed on the stainless and chrome (real chrome, not chrome painted plastic)?
I did that with my CTX1300 and kept the headers (stainless and chrome) and muffler all looking like new when I got around to doing it... which wasn't as often as I probably should have.
Before... after the entire winter season of riding in below freezing temps with some slush thrown in for good measure...
And after 15 minutes of rubbing and dipping the foil in water...
Oh, and then rinsing off and wiping with a clean cloth since the wet foil will make a grey paste as you rub. No need to rub hard.
After I did this I then went on to clean the rest of the bike. One of the few times I did that. Household aluminum foil is softer than chrome or stainless so will NOT scratch it.
RichKat
Rhome Texas
2011 ST_1300 PA
9102
Well, so much for Bar Keepers Friend
Applied a paste, let sit 10 minutes, rinse
and you can't tell I even touched it
I guess it's Simichrome and elbow grease time20220806_162727.jpg20220806_162719.jpg
