thank you John. What's an 'authority model' btw?The OEM saddle fits all years and models.
edit: except the authority models.
Thanks Eric, will go take a look at that in the morning.Welcome to the forum from Cornwall UK! Before splashing the cash, check your suspension settings for height and reboud as these can be adjusted to suit you. Also your local Car Trimmer may be able to help adjust or recover your seat with various density of foam to suit you better. I have has several seats sorted out by my local trimmer.
Yes, I realised that is what he likely meant after I askedWhat I BELIEVE John O meant by authority model was a police bike...
but could be wrong...
Welcome aboard. I have a stock seat in the shop... but I am afraid shipping to the UK might be a little pricey!
Odie1
Tom (don't know which one of you ) - I have bought 3 used Russell seats over the years. 2 did not work, 1 did that was built for a person of my comparable dimensions. I speak from personal experience not second hand and as you know I do occasionally ride a little bit. I think it has a lot to do with the size of the butt bucket and whether it has the heavy duty suspension or not.Phil,
For all the times I've read that, I've never heard anyone actually complain about used RDL experience. . Three used ones for different bikes here and the only complaint I have is with the added height which shouldn't be a problem here.
Tom
Wouldn't really matter which one of the Tom's as all three of us are of the diminutive butt size and are fine with any used RDL .Tom (don't know which one of you) ... I think it has a lot to do with the size of the butt bucket and whether it has the heavy duty suspension or not.
The standard seat will work just fine. That seat you've got on is way too low.Yes, I realised that is what he likely meant after I asked
Yes, but will exacerbate the forward lean with the OEM handlebar position for us taller riders.Like this. The difference is amazing.
You're not wrong, but after riding service bikes with similar ergonomics for many (how many!) miles it never troubled me. The first thing I did with my new ride was to remove the bar risers that the PO fitted. If the thread starter has moved to a Pan from less touring style bikes it should be good.Yes, but will exacerbate the forward lean with the OEM handlebar position for us taller riders.
I think this is some of the best advice yet. Barring significant joint damage exercising muscles might be the quickest noticeable relief while sourcing seating and riser options. It wouldn't help with banging his knees into the fairing but being able to put feet down without significant effort in a timely manner could be huge.One option is to see a physio. Tell them the problem you are having, what you need to be able to do and they will be able to tell you what exercises you need to do, how hard and how often.
I’ll inspect the hose again just to be sure and get a new clip ordered up… my macgyver fix of a cable tie probably won’t hold it either!
Phil,
Tom
