Hello all. I am having a problem with my CTX1300D (same bike for this purpose as the ST1300) and was wondering If anyone could send me in one or more directions as to where to start . The bike has been unridden for about a year but properly stored with Sta-bil and has 2500 miles. On Battery Tender.
This morning as I started the ride with a friend who also has a CTX1300 D, the bike was running fine. 10 minutes into the ride, the bike started to lose some power and run a bit erratically.
Symptoms:
Bogs down on take off and seems to have lost some acceleration.
Seems to hesitate around 3500-4000 RPM to get pass that point in high gear.
Slightly erratic at idle (not all the time).
Seems to run a bit V-Twinesque.
One pipe “seems” somewhat cooler than the other 3 (subjective appreciation).
I have included links to two YouTube videos: the good CTX (my friend’s) GOOD CTX
and the bad CTX (mine). BAD CTX
If you watch them, maybe you can hear the difference in the sound.
I already suctioned much of the gas and added fresh gas just in case. No change
Possibilities that occur to me:
Bad spark plug(s)
No spark to that cylinder- only running on 3 cylinders?
Bad coil?
I looked at the manual and for certain tests a voltage peak adaptor seems needed (I do not have one). Several other diagnostic ideas such as a bad battery, faulty side stand switch or neutral switch would seem to affect all cylinders not just one.
Besides checking all connections, I would be thankful for any ideas as to where to look given my paygrade (low) and almost as important what not attempt to do to avoid frying something.
Thanks!
Symptoms:
Bad spark plug(s)
Bad coil?
Thanks!
