load capacity can be estimated from the resistance value. If the resistance is 0.3 ohms, then a 5A load is only going to cause a 1.5v drop and things should be OK. If the resistance is 2.0 ohms, then that same 5A load is going to cause a 10.0v drop and things will not be OK.A better test on these would be a 20 watt light bulb as the ohm meter will not test it for load capacity.
hi dwalbyyes, we're talking about the same thing.
Now, if for some reason the fan doesn't come on when you ground that connector, that's what I meant by checking the voltage at the connector with the ignition switch on. Put the (+) lead on the connector, and the (-) lead on the battery negative terminal. If you don't have something close to 12v between the connector and ground, then there is a problem in the electrical path to the connector.
The other way the electrical path can fail is if there's corrosion on the ground at the radiator. That will cause a voltage drop which prevents the fan from drawing enough current to run. To test that out put your multimeter in ohms mode and measure the resistance from the radiator ground point (the base of the thermo switch) and the battery negative terminal. That resistance should only be a few tenths of an ohm, something like 0.5-0.7 ohms or so, if its a lot more than that then there's something in the ground path that needs to be cleaned up.
Hi
could anyone tell me how to separate this WIRE CONNECTOR from SW??
Yesterday my ST1100 had LLC leakage
during short touring. FAN-MOTOR didn't work at all.
I assume FAN MOTOR or its' fuse had some problem.
So i tried to separate the wire , then i wanted to connect to body for body-earthing. Because if SW has failure, direct earthing will make the MOTOR work.
But it's quite difficult to separate.
please anybody tell me how to do it.
as Larry mentioned, the thermo sensor resistance is what the temp gauge on the instrument panel uses for the position of the temperature needle. Its not the switch you're troubleshooting.I temporary ordered alternative SW instead lg 37760 MT2 003P just as trial. it's cheap only 5 dollars. it also says it will close at 85℃.
tomorrow I will exchange it.
hi LarryTwo different things.
The fan is activated by a switch that is either on or off.
The temperature gauge is controlled by a variable resistor.
hi dwalbyas Larry mentioned, the thermo sensor resistance is what the temp gauge on the instrument panel uses for the position of the temperature needle. Its not the switch you're troubleshooting.
But, as you see in the spec, the switch shouldn't close until 98C, not 85C, so that switch will close way too soon and the fan will be on almost all of the time. It seems that the fan motor was designed for intermittent duty only based on the 98C switch, but you're running it full time with the 85C switch, so that could affect the fan motor reliability. And as you say it will also put additional electrical load on the alternator, which applies more engine load than is necessary.
BTW, you mentioned earlier in your first post that the fan didn't come on in normal riding, but you didn't mention if the temperature gauge went up into the red zone when the coolant overflowed. Can you provide a bit more info on the position of the temp gauge when it overflowed. The reason I ask is because if you overflowed with the temperature gauge at halfway or less, then the problem would likely be a split in the hose, not the thermo switch failing to do its job.
the fan switch normally closes when the temp needle goes a little past the vertical position and points slightly right of vertical.
the temp needle position in your photo isn't high enough for the fan switch to close. It has to get a little higher before the switch should close. Run it up to about halfway between where it is in the photo and the far right end of the white arc, if it doesn't come on then for sure the switch is the problem.hi dwalby
here's a photo of overflow.
as posted to Larry, the water temp gauge iseems allocated to FILLER NECK lower position.
yes 85℃ is way too much low to work.
i tried again last night, and confirmed FAN didn't work even high temp.
my college also agreed that the FAN SW must have failure. need to exchange...
You can hook up an ohm meter to that switch, the positive to the switch and the negative to ground.. when the ohm meter reads between 10-15 ohms the fan will generally come on, the thermostat opens around the 45 ohm mark. ( that’s from memory I will edit and confirm once I look at my Clymers)i thought water temperature gauge is allocated to just bottom of FILLER NECK,
thank you kiltmanYou can hook up an ohm meter to that switch, the positive to the switch and the negative to ground.. when the ohm meter reads between 10-15 ohms the fan will generally come on, the thermostat opens around the 45 ohm mark. ( that’s from memory I will edit and confirm once I look at my Clymers)
No, there are two separate sensors, a switch for the fan and a variable resistor for the gauge.You can hook up an ohm meter to that switch, the positive to the switch and the negative to ground.. when the ohm meter reads between 10-15 ohms the fan will generally come on, the thermostat opens around the 45 ohm mark. ( that’s from memory I will edit and confirm once I look at my Clymers)
I provided this information as another way of determining if the system is functioning properly.
hi dwalbythe temp needle position in your photo isn't high enough for the fan switch to close. It has to get a little higher before the switch should close. Run it up to about halfway between where it is in the photo and the far right end of the white arc, if it doesn't come on then for sure the switch is the problem.
