You could always shop for a crappy taillight assembly to take the plug and wiring from.
No, NO, NOOOO!!!Just checked, the socket is $9.25 at Ron Ayers. Plus some Dremeling, soldering, and a bit of JB Weld
I actually considered if it was possible to amputate the socket from a tail light assembly having found the male as a result of a spiderman post.Just checked, the socket is $9.25 at Ron Ayers. Plus some Dremeling, soldering, and a bit of JB Weld
Just an FYI — I have a Strobes n More 3 LED strobe connected directly to a brake light terminal. When using the brakes the factory brake lights also pulse very slightly. It's not too noticeable because of the strobe (no surprise) but it tells me that there's a noticeable current draw the factory brake lights are really happy with. Maybe tapping the Whelan elsewhere might be better. Or use a relay? That's a bit much especially if there's a higher capacity feed somewhere.My brake light project involves a Whelen LIN3 and the Givi light kit for my top case.
Tapping the circuit at the rear seems much neater than at the rear pedal.
Yeah, me too for a hot minute before I tracked down the male connector. As soon as you factor in the cutting, carving, soldering, etc... to adapt the lamp socket for this purpose, you've already spent nearly the same amount on the socket vs. the connector and your result is a seriously inferior component. Plus, your modified socket will likely be significantly larger than the connector making it harder to package in the limited space in the tail section and will be more difficult to weatherproof, etc, etc... Honestly, there is only one correct way here people.I actually considered if it was possible to amputate the socket from a tail light assembly having found the male as a result of a spiderman post.
No. $11 for only the male connector (on the right) and extra terminals. Joe added the female connector to show its mate.
Useful observation @ST Gui . Are you running LED brake/taillamps or still OEM incandescent? LEDs should draw less current than with equivalent light output compared to incandescent. The later can vary noticeably with small fluctuations in voltage where LEDs are more tolerant. I've converted every lamp on my bike to LED and at the moment the only additional rear lighting are the OEM Givi LED lights for my Maxia V56 tailbox. And they're currently wired into the brake circuit.Just an FYI — I have a Strobes n More 3 LED strobe connected directly to a brake light terminal. When using the brakes the factory brake lights also pulse very slightly. It's not too noticeable because of the strobe (no surprise) but it tells me that there's a noticeable current draw the factory brake lights are really happy with. Maybe tapping the Whelan elsewhere might be better. Or use a relay? That's a bit much especially if there's a higher capacity feed somewhere.
It hasn't been enough to motivate me to find an alternate location. Just thought I'd pass that on as a heads up.
An amusing turn of phrase! My brake/tail lights are LED. I never noticed if the factory incandescents also pulsed but thinking back they might have. But the LEDs are so responsive that the slower reacting incandescent filaments might have made any pulsing harder to notice. Maybe.'terminal generosity'
Yeah, eerily similar.
Have a look at the below;I'd like to find an amber/red switchback bulb with the correct base to turn them into a turn signal (amber) / brake (red) light.
Thanks Andrew. I had seen this message a while ago before I embarked on my project. It's helpful to look back and see the path others have taken. Thanks!Have a look at the below;
Rear turn Signal - Red/Amber switchback Led mod - ST1300
Negative... only one brake flasher per vehicle if done right. The key is that the output to ALL the brake lights must pass through this flasher to ensure every bulb is synchronized.I'm curious why they are seeking 6 at a time. Do you need a controller each bulb?
I would not recommend that all of the brake lights pass through a flasher module. If the flasher module fails, a dangerous scenario where there are no brake lights at all is the result.The key is that the output to ALL the brake lights must pass through this flasher to ensure every bulb is synchronized.
Noted @Andrew Shadow One of my goals with this approach is to enable reconfiguration with minimal effort; pretty much rearranging wires and terminals within the connectors.I would not recommend that all of the brake lights pass through a flasher module. If the flasher module fails, a dangerous scenario where there are no brake lights at all is the result.
I ran my centre high mount brake light and my top case brake light through the flasher module. I left my OEM brake lights untouched so that they do not run through the flasher module.
That's what I did in the video for mine. The OEM tail light works as designed (with LED bulbs) and the add on brake lights (under the top case and above the rear plate where the reflector was) work off the flasher. If the flasher fails I still have some lights (assuming I don't blow a fuse.) I debated about adding a relay in between just for isolation.I would not recommend that all of the brake lights pass through a flasher module. If the flasher module fails, a dangerous scenario where there are no brake lights at all is the result.
Don't I know it!It would have been much easier and cleaner if there had been that single connector in the harness. It's a crying shame that it takes almost $60 worth of connectors to cleanly make an adapter.
