Where did you get your small fender extender?
It looks like both would fit better if they were swapped where they come out of the coil.Your number 3 probably belongs like my 2006 was made. Sharp corner on the wire.
Your plug cap is positioned wrong!Your number 3 probably belongs like my 2006 was made. Sharp corner on the wire.
No.It looks like both would fit better if they were swapped where they come out of the coil.
Your correct John, but the tail of the cap and wire is supposed to be pointing upwards at an angle.The shorter one MUST be routed over the main harness - otherwise the plug will definitely not lift out.
