Suspension question
portugal
Hi all. I have a 1999 non-ABS 1100. First time I have riden her since purchase and rebuild. I fitted a YSS rear shock because the stock one was past it's best. I felt the bike was fairly stable on most roads but a little 'unsure' at the rear on bumpy corners.I have dialed in for approx 1.5" sag and put 10-clicks on the damping as a start point. I have left the shock length as it came from the factory but am aware it is possible to change that but need to know the effect on the front handling. Unfortunately, after the ride I found the right fork seal is leaking so no more tests until that is sorted. When I replace the seals, do I need to replace the bushes or are they usually OK? the bike has done around 60,000miles. Also, what oil is recommended? 5 wt or 10 wt? I weigh 100kg.
Any help/advice on setting up the front and rear suspension would be gratefully received.
TIA
Depends on usage, (in)frequent fork oil changes, etc...
You'll see the wear of the gray Teflon coating...
I'd get and replace the bushings anyway... + the copper rings for the bottom bolts...
O-ring set for the anti-dive...
Nylon bush & steel clip for the actuator...
I run Hyperpro springs and like 7W oil...
IIRC, the 1300 shop manual shows wear patterns on the fork bushings - sort of a go-no go picture for replacement. Not sure if your 1100 manual has the same drawings. I had little visual wear on mine in the high 20''s to 30,000 miles when I changed the valves to RaceTech's Gold Valves. At 60K, I'd order and replace all wear parts as a matter of course.
Minnesota
2012 ST 1300
007798
8560
As to your question on handling, the lower the rear the less weight is on the front. At some point the front end becomes light, especially in high wind or following semi trucks and the handling will suck. The stock ride height was set by Honda for a reason. YMMV.
IIRC, raising the rear will 'quicken' the steering. You can accomplish the same to some extent with more preload. This is why you set up the bike's sag to the stock configuration and then adjust the suspension to suit the rider and conditions. Experienced mechanics can dial a car (or bike's) suspension in for a particular race track and then fine tune it for the conditions of the race and the driver's wishes. They can come close, but there is almost always some final adjusting.
Richmond, VA
'01 & '96 ST1100s
9007
Understood, but there is no one "stock" ride height as everyone and their loads are different, which your "YMMV" alludes to.
To me, the goal is optimum handling, with minimal and equal steering effort required to both lean the bike over and to return it upright.
Are these part of the anti-dive or ....? (service parts) . My forks are coming off one of these days .
It's where the front caliper bracket actuates the plunger when under load...
The nylon bushing eliminates rattle/knocking...
loc 39 (P/N 51545MJ0003, bushing) & 26 (P/N 51445MJ0003, ring stopper)
