Hi all. I have a 1999 non-ABS 1100. First time I have riden her since purchase and rebuild. I fitted a YSS rear shock because the stock one was past it's best. I felt the bike was fairly stable on most roads but a little 'unsure' at the rear on bumpy corners.I have dialed in for approx 1.5" sag and put 10-clicks on the damping as a start point. I have left the shock length as it came from the factory but am aware it is possible to change that but need to know the effect on the front handling. Unfortunately, after the ride I found the right fork seal is leaking so no more tests until that is sorted. When I replace the seals, do I need to replace the bushes or are they usually OK? the bike has done around 60,000miles. Also, what oil is recommended? 5 wt or 10 wt? I weigh 100kg.
Any help/advice on setting up the front and rear suspension would be gratefully received.
TIA
TIA
