PS don't drop the plug on concrete , It is now trash.
What would you say about this conclusion?
if your lucky, Standard spark plug gaps will wear much faster. The electrode gap normally increases from spark firing and this happens faster with standard plugs. Iridium plug gaps wear more slowly so they will last 100K miles or a little more. Regular plugs will wear out in 15K miles and platinum plugs wear out in 30–50K miles.As will any standard plug in a properly running engine.
I am not disagreeing with you that an iridium plug has a longer life-span. My point is that to claim that the switch to iridium plugs is to take advantage of the greater change interval afforded by their increased life-span and to then replace them every 15 or 20,000 miles is false economy and makes no sense. The standard plugs will easily last double that mileage, so there is no gain at all unless the interval is significantly increased. If a person is going to replace their spark plugs that often, they would be far better off to buy the standard plugs and put the cost difference in their gas tank.if your lucky, Standard spark plug gaps will wear much faster. The electrode gap normally increases from spark firing and this happens faster with standard plugs. Iridium plug gaps wear more slowly so they will last 100K miles or a little more.
Sure, in the days of points and condenser ignition systems and carbureted engines running leaded gas that was true. Spark plugs needing to be changed at 15,000 mile intervals has not been the case since electronic ignition and fuel injection became standard. Regular plugs do not wear out anywhere near 15,000 miles unless they are some cheap counterfeit made-in-China rip-offs or their is something wrong with the vehicle that precipitates premature spark plug failure. As far back as the mid to late eighties the spark plugs delivered with a new vehicle were warranteed for 80,000 KM/50,000 miles under government emissions regulations, as were all other parts that fell under that legislation.Regular plugs will wear out in 15K miles ......
My truck is a 2010 and it came from the factory equipped with iridium plugs. The first inspection and replacement of the spark plugs is called for at 160,000 KM/100,0000 miles, and every 160,000 KM/100,00 miles thereafter. This is with the iridium spark plug technology of 20 years ago. I would hope that the current technology is superior, so the numbers that you are offering make no sense....... platinum plugs wear out in 30–50K miles.
But clean, well-adjusted CV carbs do a pretty good job.A carb is designed to operate at most efficient at wide open throttle. fuel injection adjusted where carburetors could not.
Why would anyone change iridium plugs after 15-20k, makes no sence, as soon as they pulled them out they would appear brand new, they have not degraded. It's like changing your synthetic oil every 3000 miles.I am not disagreeing with you that an iridium plug has a longer life-span. My point is that to claim that the switch to iridium plugs is to take advantage of the greater change interval afforded by their increased life-span and to then replace them every 15 or 20,000 miles is false economy and makes no sense. The standard plugs will easily last double that mileage, so there is no gain at all unless the interval is significantly increased. If a person is going to replace their spark plugs that often, they would be far better off to buy the standard plugs and put the cost difference in their gas tank.
My point exactly, but this is what some people do and why I am often at a loss to understand the logic used to make this switch to iridium plugs. Anyone changing standard plugs at 15,000 miles is throwing away money, let alone doing so with iridium plugs.Why would anyone change iridium plugs after 15-20k, makes no sence, as soon as they pulled them out they would appear brand new, they have not degraded. It's like changing your synthetic oil every 3000 miles.
These are not new regulations. Every dealer should be familiar with them. The original regulations came out in the US in 1972 and have been amended over time. I was a mechanic at a GM dealership for many years, which is why I am familiar with this because so much of the work that we did was under warranty. I was not responsible to US regulation but as far as I know in the US this fell under the Clean-Air Act regulations. We had similar legislation here in Canada. The regulations were very similar in both countries as is most often the case with automobiles.As far as this "As far back as the mid to late eighties the spark plugs delivered with a new vehicle were warranteed for 80,000 KM/50,000 miles under government emissions regulations, as were all other parts that fell under that legislation." I have works at a few new car dealerships over the last 40 sum years and never ever heard of such a thing.
I also worked for gm ( loved those electronic carbs) and mopar but our (US) Fed standards must be way different than Canada. US (epa) standards only covered ECM an converters for 8/80k miles all the other stuff was 2/24. This article explains 95 and newer but it was all I could find https://mde.maryland.gov/programs/A....mde.state.md.us/assets/document/warr95fs.pdfMy point exactly, but this is what some people do and why I am often at a loss to understand the logic used to make this switch to iridium plugs. Anyone changing standard plugs at 15,000 miles is throwing away money, let alone doing so with iridium plugs
Specified emissions parts fell under federal government regulations that mandated that in the case that these parts failed they had to be replaced under the warranty stipulated in the regulation regardless of what the manufacturers warranty was. At the time this was 5 years or 80,000KM in Canada, 50,000 miles in the US. Spark plugs were included, as well other specified parts whose performance directly affected emissions such as catalytic converters, EGR valves, high tension wires, etc.. In the US starting in the mid ninties the regulations changed and fewer parts were included on the list but the warranty period was extended to 8 years or 80,000 miles for the specified emissions parts. I have no idea what the current regulations are.
There are NGK plug problems on the advrider.com BMW GS forum. I checked my 2022 R1250GS plugs at 12,000 miles, they looked good, and were junk at 16,000 miles. No definite fix other than to replace them at 12,000 miles at $50.00 for the pair.As will any standard plug in a properly running engine.
Could those NGK problems actually have been counterfeit issues as Igofar mentioned earlier in this thread...?There are NGK plug problems on the advrider.com BMW GS forum. I checked my 2022 R1250GS plugs at 12,000 miles, they looked good, and were junk at 16,000 miles. No definite fix other than to replace them at 12,000 miles at $50.00 for the pair.
Mine were OEM from new……and per the info I read appeared to be genuine NGK plugs. Maybe BMW bought a defective supply of plugs?Could those NGK problems actually have been counterfeit issues as Igofar mentioned earlier in this thread...?
I know, I already referred to those changes.I also worked for gm ( loved those electronic carbs) and mopar but our (US) Fed standards must be way different than Canada. US (epa) standards only covered ECM an converters for 8/80k miles all the other stuff was 2/24. This article explains 95 and newer but it was all I could find https://mde.maryland.gov/programs/A....mde.state.md.us/assets/document/warr95fs.pdf
Before these changes were made in the mid nineties many more parts were included in the US and Canadian emissions regulations.In the US starting in the mid ninties the regulations changed and fewer parts were included on the list but the warranty period was extended to 8 years or 80,000 miles for the specified emissions parts. I have no idea what the current regulations are.
So far at least, that seems to be a problem with a specific iridium spark plug, and is not indicative of overall spark plug life expectancy be they standard or iridium.There are NGK plug problems on the advrider.com BMW GS forum. I checked my 2022 R1250GS plugs at 12,000 miles, they looked good, and were junk at 16,000 miles. No definite fix other than to replace them at 12,000 miles at $50.00 for the pair.
plug or engine?So far at least, that seems to be a problem with a specific iridium spark plug, and is not indicative of overall spark plug life expectancy be they standard or iridium.
So my above joking comment that it could be a BMW issue might actually be right, due to their possible design specifications to manufacture...??So far at least, that seems to be a problem with a specific iridium spark plug, and is not indicative of overall spark plug life expectancy be they standard or iridium.
plug or engine?
No clue to both questions. I'm not paying attention to it as I don't have a BMW and I don't use iridium spark plugs.So my above joking comment that it could be a BMW issue might actually be right, due to their possible design specifications to manufacture...??
Al:As far as this "As far back as the mid to late eighties the spark plugs delivered with a new vehicle were warranteed for 80,000 KM/50,000 miles under government emissions regulations, as were all other parts that fell under that legislation." I have works at a few new car dealerships over the last 40 sum years and never ever heard of such a thing.
