You don't really need a siphon. If you don't want to wait for it to arrive, see the below method that will drain all but a few ounces of fuel from the lower tank.
Draining the Lower Tank
(Courtesy of John, AKA BakerBoy on ST-Owners.com)
If you want to drain both of your fuel tanks, leaving only a small amount of gas where the pump doesn't go, remove the hose labeled #6 in the below picture and
QUICKLY attach a similar size hose to the exposed nipple. Lead the hose to a very big gas can!
1. Have a big gas can with you!
2. There will be hardly any gas left in either fuel tank.
3. Be quick swapping the two hoses when you first start out. You will lose a little gas, but the quicker you are the less you will lose!
The below photo shows the lower fuel tank hose connections.
There are 4 fuel connections on top of the lower fuel tank, numbered as indicated in the picture above:
1- Small hose that vents lower fuel tank vapours into the upper fuel tank.
4- Large hose that connects the upper fuel tank to the lower fuel tank.
5- Pressurized fuel delivered out of the fuel pump to the fuel rail above the throttle bodies.
6- Depressurized excess fuel returned from the fuel rail.
The image below shows the upper fuel tank hose connections.
1- Vent tube to allow air to escape the lower fuel tank during fill-up.
2- Breather tube connected the charcoal canister.
3- Drain tube to evacuate fuel spills or water from around the upper tank filler neck.
A- Electrical harness for the fuel level sensors.
