ok ST gurus, I got my Rostra in, stripped the bike down, and ordered a GW switch plus a AT&C pulse devider. Im going to use 1500 gw throttle cables (6" longer) has anyone used the atc devider? the z063 was out of stock
I used the F6B GL1500 control and the cables that came with it.
The cables are too long, I had to make a few "S" curves to make it fit.
I used a replacement for the divider listed in the article, it was for a taxi.
I had to move the brake master cylinder all the way foreward,
I made a spacer to fill in the gap at the end of the hand gripe where the handle bar weight mounts.
Be careful and position the control so it does not hit the fuel tank, very carefully drill the new hole for the locating pin,
Measure and jig it up several times before drilling!!!
