Listed below is what I carry - there are a few issue's with after market tool kit's:
Spark plug - make sure it will fit the plug hole and reach the plug's.
One of the things I do is only use my tool kit when working on the bike, if I do not have the tool in my kit that I need then I need to add it but the other side is if I have tool's in my kit and never use them they are taken out. Note: my tool kit is just a small tool bag, easily held in one hand.
With these tools you will be able to: Remove both wheels, remove all the plastic, check under the tank cover, replace the fuel filter, change out the battery, repair a flat, change oil, adjust anything adjustable, replace brakes pad?s, tighten almost anything on the bike, replace the front forks?.etc?.
Screw driver?s;
Phillips #2 bit (magnetized) (2) 1-small, one larger.
The shaft should fit in the small hole?s in the front axle.
Flat blade #2
Wrenches: (open/box end)
6mm ? Can be used on a #6 Allen wrench for extra leverage.
8mm
10mm - (2)
12mm ? Right rear exhaust pipe.
14mm ? Rear brake
17mm ? Oil drain plug. (oil filter remover for long trips)
Sockets:
3/8 ratchet
3? extension (2)
Drive reducer 1/2? to 3/8? drive, and 3/8? drive to 1/4?
6mm, 8mm, 10mm, 12mm, 14mm ? rear brake, 22mm ? front axle (1/2 drive), 27mm rear axle (1/2 drive)
Spark plug socket ? need to make sure it fit?s the hole ? standard Honda unit
works well.
6mm (front axle, brakes, all plastic), Allen wrench socket (nice to have)
Allen wrenches:
6mm, Plus a 7.5 (about) - take a old (cheap new) 8mm and grind it down to fit the rear axle
Pliers;
Small needle nose, with a 45 degree bent tip ? great for removing/installing
the small plastic pins.
Standard pliers
Magnetic pickup (looks like a pen) that extends to about 16?.
Paint brush;
Short handle 1 ? - 2? wide paint brush. (Great for cleaning areas before getting dirt in your oil,
under the seat, gas tank, etc.)
Tire repair kit.
Flashlight
Tie?s, tape and some short wire.
PLUS; any tools needed to cover your ?Farkles?
You should always learn how to remove your wheels, someone may come along and offer help but they are unable to transport the bike. Most likely you could put the wheel in the truck. Just to make it more real, remove the wheel in the dark with only a flash light and have the water sprinkler covering the whole area you are working in?.
