Larry, need to know how pumping the front lever gets the SMC to pump fluid without the front wheel turning. Inquiring minds.
After using one at John's a couple weeks a go, I'm a believer in the MP brake bleeder. Need to order one for myself. Need the answer to the above question as my 01 is an ABS model. I've used the MityVac up 'til now.
Good Question! I believe the reason the manual instructs us to remove and tilt the left caliper, is to get the casting bump for the SMC to the highest spot, so when we do bleed, it will also bleed fluid out of the SMC also. I've also tried pumping or pushing the smc forward during bleeding, but found it did nothing at all. When I removed the SMC a few months back to replace in innards, only about a thimble full of fluid came out, and it was clean fresh fluid, so I'm guessing the bleeding routine takes this into account in the tilt process. The corrosion that causes the SMC to fail, IMHO, most times happens in front of the plunger, underneath the boot, just inside the cylinder. The plunger then drags, or gets stuck. Now once this happens, the fluid may go bad as some have reported. But I bleed my systems about every 6 months, and have not found any goop inside the system so far.
As far as ABS non ABS, the bleeding routine is the same.
I've used the MP tool, or manual method, with both ABS and Non ABS ST's as well as wings with no problems.
My GL1800 manual goes into much more detail in the bleeding process, stating that you can bleed it either with a vacume pump, or if one is not available, using the manual method. It states either method is acceptable.
There are no comments in any of the manuals suggesting that there is a separate method for bleeding the SMC.
I've also heard several folks swear that the PCV cannot be bled without a vacume pump as well!
Simply put a hose on the fitting, crack the bleeder, and push down on the foot pedal a couple times and see what happens. I truly don't understand why folks have problems with the PCV either.
Please feel free to PM me if you'd like to discuss it in more detail. I feel I was truly at a loss by not meeting you in person at the tech event. I've heard you are the TRUE ST WHISPERER :bow1:
